PIC16F84A Tachometer LED routine
Results 1 to 21 of 21
    Oct 2008
    Denmark
    Default PIC16F84A Tachometer LED routine
    I'm writing a routine to a tachometer. I just doesn't work! I've searched the forum, but i haven't found anything that looks like this.
    '*  Name    : Tacho.BAS                                         *
    '*  Author  : Christian Lerche                                  *
    '*  Notice  : Copyright (c) 2008 Lerche                         *
    '*  Date    : 07-10-2008                                        *
    '*  Notes   : PIC16F84A @ 10 Mhz XT                             *
    '*          : XT osc, BODEN off, WD off                         *
    'Include------------------------------------------------------------------------
    'Definitions--------------------------------------------------------------------
    Define osc 10                          ' Define Osc as 10 Mhz
    DEFINE PULSIN_MAX 25000                ' Lowest RPM 600
    'Inputs/outputs-----------------------------------------------------------------
    TRISB = $80                            ' All PortB Output
    TRISA = $f0                            ' All PortA Output
    INPUT PORTA.4                          ' PortA.4 Input
    'Variables----------------------------------------------------------------------
    B0 VAR BYTE                            ' Define B0 as byte
    W1 var WORD                            ' Define W1 as word
    'Main program-------------------------------------------------------------------
    loop:
            IF PORTA.4 THEN                ' Wait until start of low pulse
                    GOTO MAIN1
                    GOTO loop
    MAIN1:
            PULSIN PORTA.4,0,W1            ' Measure pulse-width in 4µS resolution
            GOTO MAIN
    MAIN:
            W1 = W1 * 4                    ' Convert µS to mS
            W1 = (60000 / W1)              ' Revs in 60 mS
            W1 = W1 * 1000                 ' Revs in 60 sec
                GOSUB display              ' Go to display sobroutine
            GoTo LOOP                      ' Do forever
    'Display subroutine-------------------------------------------------------------
    display: B0 = W1 / 1000	               ' Find number of thousands
    	W1 = W1 // 1000	                   ' Remove thousands from W1
    	   Gosub bin2seg	               ' Convert number to segments
    	PortB = B0	                       ' Send segments to LED
    	PortA = $17	                       ' Turn on fourth digit
    	Pause 1    		                   ' Leave it on 1 ms
    	PortA = $1F	                       ' Turn off digit to prevent ghosting
    	B0 = W1 / 100	                   ' Find number of hundreds
    	W1 = W1 // 100	                   ' Remove hundreds from W1
    	PortA = $1B	                       ' Turn on third digit
    	B0 = W1 / 10	                   ' Find number of tens
    	W1 = W1 // 10	                   ' Remove tens from W1
    	PortA = $1D	                       ' Turn on second digit
    	B0 = W1		                       ' Get number of ones
    	PortA = $1E	                       ' Turn on first digit
        Return		                       ' Return to main
                                           ' Routine copied from ledart.
    'Lookup table-------------------------------------------------------------------
    bin2seg:
        Lookup B0,[$40,$79,$24,$30,$19,$12,$02,$78,$00,$18],B0
    Anyone got a clue, what is does wrong?
    Thanks in advance!
    / ThaSanta
    What part does not work?
    Wink
    Hi, Santa ( de bois )
    1) Just the usual gag with PORTA.4 ...
    Did you place an external pullup resistor or something to drive the pin to HIGH state ???
    2) I note 10 Mhz need a HS Osc ... ( but generally works with XT !!! )
    3)
    MAIN1:
            GOTO MAIN
    you'd better try
    MAIN1:
            RCTIME PORTA.4,0,W1            ' Measure pulse-width in 4µS resolution
            GOTO MAIN
    4) your Mathematics are really bad for INTEGERS using ...
    you'd much better use DIV32 ...
    That's the first hits ...
    Oct 2008
    Denmark
    Sorry for letting the problem out (I was kinda tired).
    The attached image views the first digit of 4. As if the algorithm doesn't calculate the RPM correct.
    1) - I have not yet build the circuit, as I don't have a programmer.
    2) - I don't think the Simulator cares about HS or XT :-)
    3) I wrote RCTIME instead of PULSIN, but it didn't chance anything.
    Actually, after reading the manual to PBP, i don't know how to use DIV32.
    I've tried examples, but I still can't figure it out.
    - Thanks again guys. :-)
    Red face is the Pic the good one ??? ... not so sure.
    The most annoying thing in your project is ... the PIC must drive continuously the 4 digits AND while that, must measure the rotation period.
    I think you'll quickly understand you'll have to use interrupts and ... a 16Bits timer ... what the 16F84 doesn't have aboard ...
    so, you'll also have to watch for TMR0 overflows ...to increment a 8 bits counter for the timer Upper 8 bits counting.
    Not really easy ( "asm" recommended here )... but doable.
    seeing your pain for the first steps ... I'd recommend you to switch to a 16F628a that has everything to EASILY realise such a RPM meter. ( I mean the capture module ... )
    The project is yours ... you are the one who decides !!!
    Only applies when using PortA.4 as an output...
    Quote Originally Posted by ThaSanta View Post
    Arg! Simulators!
    Oct 2008
    Denmark
    I'll go along and try to use the CCP on Pic16F628A :-)
    I'll be back with updates.
    Thanks for the fast replies!
    / Lerche
    edit:all good . . .
    Here's one small problem...
    http://www.picbasic.co.uk/forum/showthread.php?t=558
    Oct 2008
    Denmark
    I really think somethings wrong with the math. I just can't figure it out :/
    Now an example:
    MAIN:
            W1 = W1 * 2                    ' To get whole period
            W1 = W1 * 4                    ' now the count is in mS
            W1 = (60000/W1)                ' Revs per 60 mS
            W1 = W1 * 1000                 ' Revs per minute
    The input has a period of 12 mS (5000 RPM) - Which is 1500 increments @ 4µS.
    As I only measure the low part of the 50% duty-cycle, I multiply with 2. Full period.
    Then I multiply with 4. Now it's in mS. 12,000.
    60,000 / 12,000 = 5.
    5 * 1000 = 5000 RPM. NICE! - But i doesn't work.
    I have seriously no idea of why this shouldn't work.
    EDIT:
    And then i thought. Figure out when i goes wrong:
    So i tried to make the calculations. With a number, that wouldn't go straight up into 60,000. Example: 2000.
    2,000*2=4,000
    4,000*4=16,000
    60,000/16,000=3.75 <- I guess this is were the PIC can't follow my lead.
    3.75*1,000= 3750.
    / Lerche
    EDIT:
    2,000*2=4,000
    4,000*4=16,000
    3.75*1,000= 3750.
    Well, since PicBasicPro (nor the PIC itself) doesn't support floating point variables, it's not surprising...
    Apr 2007
    loop:
                    GOTO MAIN1
                    GOTO loop
    MAIN1:
            GOTO MAIN
    MAIN:
    bin2seg:
    Thanks in advance!
    / ThaSanta
    Please check this line:
    loop:
    Should it be:
    IF PORTA.4 = 0 THEN ' Wait until start of low pulse
    Andy
    Quote Originally Posted by Andy Wood View Post
    loop:
    Should it be:
    Andy
    Unless he's just making sure that the timing loop doesn't start in the middle of the pulse...
    Oct 2008
    Denmark
    loop:
    Should it be:
    Andy
    - As Skimask says: I am making sure it is not starting from the middle of a period
    / Lerche
    Question
    Hi Christian,
    I'd like to be sure of one thing : what do you use as a rotation detector ???
    ... as in your calculations, the pulsin signal is supposed to be equal to the rotation period, something hurts me ... but what ???
    Oct 2008
    Denmark
    Hi Christian,
    As it is, I am only using a simulator. I do not have a programmer.
    Actually, it's supposed to measure the RPM of a computer-fan. 50% duty-cycle. :-)
    / Lerche
    ThaSanta, Here is a snipit of code I wrote about 4 years ago to do exactly what you are requesting..
    PutMulResult macro Const32
    MOVE?CB low Const32, R2
    MOVE?CB low (Const32 >> 8), R2 + 1
    MOVE?CB low (Const32 >> 16), R0
    MOVE?CB low (Const32 >> 24), R0 + 1
    PULSIN B_IN,1,POINTER1 'MEASURE HIGH PULSE
    IF POINTER1 > 0 THEN
    @ PutMulResult 15000000 ' Load PBP internal vars Max= 2,147,483,648
    POINTER2 = DIV32 POINTER1 ' Divide 15000000/(PERIOD/2)
    SCRATCH = R2 ' Get remainder of Div32
    ' Change remainder to Decimals
    SCRATCH = SCRATCH * 10000 ' Multiply remainder * 10,000
    SCRATCH = DIV32 POINTER1 ' Divide remainder by original divisor
    POINTER2 = 0
    SCRATCH = 0
    LCDOUT $FE,LINE(1)
    PAUSEUS 100
    LCDOUT DEC5 POINTER2,".",DEC4 SCRATCH
    I hope it works for you... It did for me...
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 05:59
  3. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 09:42
  4. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 21:19
  5. LCD will not start
