Mathematical calculation
Results 1 to 17 of 17
    Talking
    Hi, Russ
    You're right; In French , Accuracy ... is told "precision" ... so, I sometmes mix the words !!!
    I see we have the same readings ... lol !
    BTW, I have found some nice sliding rules in the ex Communist part of the world ... I just love to use it : always reminds me what's necessary for life.
    one interesting tool for such work is this one :
    http://curveexpert.webhop.net
    Helps a lot for decent linearizations ...
    Omaha, Nebraska USA
    My apologies, Alain. I have no French and do not know how different words and concepts translate. I help amindzo to find the calculations he needs, and to learn which ones he needs.
    In my youth, I learned Hebrew; Latin in high school; and Greek at university. Not much of that helps you or me or amindzo today!
    The very first slide rule I used, in 1963, was this one:
    http://foraker.research.att.com/~dav...tt/n1010es.jpg
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    Iran
    thank you everybody,i think it's better to use the second method in application note,temperature is very important for me but humidity is not as important as temperature so i think i should use second method.
    Wink Nostalgy ...
    Timeo Danaos et Dona Ferentes ...
    cheers
    Omaha, Nebraska USA
    Quote Originally Posted by amindzo View Post
    If you use 12-bit data for SOrh, the first method in the application note is a better choice. The second method is easily implemented for 8-bit SOrh.
    Russ
  1. Calculation Problem - value goes to zero after 65
    Last Post: - 12th March 2010, 05:10
  2. how to add the calculation of temperature in my source code
    By slimpeng in forum mel PIC BASIC Pro
    Last Post: - 20th February 2008, 16:31
  3. Mathematical problem
    By iugmoh in forum General
    Last Post: - 25th January 2008, 18:24
  4. Need help with lookup table or direct calculation
    By nverma in forum mel PIC BASIC Pro
    Last Post: - 11th October 2006, 18:27
  5. Mathematical Precedence
    By keithdoxey in forum mel PIC BASIC Pro
    Last Post: - 6th October 2006, 21:44
