Mathematical calculation
Results 1 to 17 of 17
    Omaha, Nebraska USA
    Lightbulb
    Important questions here are how precise and how accurate does your result need to be? (There is a difference between precision and accuracy.)
    The formula you give compensates for the non-linearity of the sensor, and it is from the product data sheet, section 4.1:
    http://www.sensirion.com/en/pdf/prod...nsor-SHT7x.pdf
    Warning: Do not try to use anything like:
    RH=(0-2046800+(36700*(SORH*1000000))-((SORH*1000000)*(SORH*1000000)*1595500/10000
    ("Danger, Will Robinson!")
    Substitute 2353 (approximately 76% RH) for SOrh in the above formula and you will see why. (I get something like 883 quintillionths of a percent . . . very dry humor, indeed.)
    Suggestion:
    For the 12-bit data for which it is intended, the formula can be reduced, with some loss of precision, to:
    %RH = (SOrh/27) - [(SOrh)(SOrh)/627,000] - 2
    Again using 2353 (for 75.79% RH, according to the manufacturer), this gives 76.3; the manufacturer's formula gives 75.5.
    The 12-bit output from the sensor ranges from 0 (for 0%) to about 3400 (for 100%). I'm guessing the 8-bit output goes from 0 to about 212, so you may be a lot happier using the 8-bit output. (212 squared is 44,944; the square root of 65,536 is 256. But 2353--for about 76% RH--when squared is over 5.5 million!)
    By the way, that is only compensating for non-linearity of the sensor itself; compensation for temperature is given in 4.2. (A 10 degree difference from 25 Celsius amounts to an adjustment of 1.2 percent RH, an increase if more, a decrease if less.)
    The manufacturer provides an application note that gives three other ways to calculate the compensated value for non-linearity; the first two methods are much simpler and ideally suited to a microprocessor application. The formulas are given for both 8 and 12 bits:
    See section 2 of: http://www.sensirion.com/pdf/product..._Sensors_E.pdf
    If an accurate result, precise within a percent or two, plus or minus, is acceptable, you should have no problem. If you need help converting the factors in the tables of sections 2.1 or 2.2, just ask.
    Another suggestion: It is easier to divide by a whole number than to multiply by a decimal fraction.
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    Talking Significant or not digits : a whole laughing matter.
    Hi, Amindzo
    As the sensor is given for a basical 2% RH precision .... do you think all those intellectual self-indulgence calculation mean anything ???
    certainly not.
    just consider your result is "inside" those limits.
    Just for laughing : which reference and how many points will you use to calibrate your sensor ??? ( good question, no ??? )
    Alain ( Thermics and Thermodynamics Engineer ... BTW.)
    Omaha, Nebraska USA
    Hi, Amindzo
    certainly not.
    The document Alain refers to specifies accuracy, not precision. Accurate data may be precise or imprecise. Inaccurate data may also be precise or imprecise.
    I prefer imprecision of accurate data to precision of inaccurate data. Someone who has used both a slide rule and an electronic calculator feels this intuitively, in his gut.
    Of course, what we all want is both accuracy and precision. That's why God invented calibration and told engineers to do it.
    amindzo, I'm showing you ways to do the calculations; Alain is telling you you don't need them. He may be right . . . but you still have to convert the raw SOrh into %RH, and the formulas will help you do that.
    I'm also obliged to note that the document to which Alain refers is 6 years out of date.
    Russ
    Talking
    Hi, Russ
    You're right; In French , Accuracy ... is told "precision" ... so, I sometmes mix the words !!!
    I see we have the same readings ... lol !
    BTW, I have found some nice sliding rules in the ex Communist part of the world ... I just love to use it : always reminds me what's necessary for life.
    one interesting tool for such work is this one :
    http://curveexpert.webhop.net
    Helps a lot for decent linearizations ...
    Omaha, Nebraska USA
    My apologies, Alain. I have no French and do not know how different words and concepts translate. I help amindzo to find the calculations he needs, and to learn which ones he needs.
    In my youth, I learned Hebrew; Latin in high school; and Greek at university. Not much of that helps you or me or amindzo today!
    The very first slide rule I used, in 1963, was this one:
    http://foraker.research.att.com/~dav...tt/n1010es.jpg
    Russ
    Iran
    thank you everybody,i think it's better to use the second method in application note,temperature is very important for me but humidity is not as important as temperature so i think i should use second method.
    Wink Nostalgy ...
    Timeo Danaos et Dona Ferentes ...
    cheers
    Omaha, Nebraska USA
    Quote Originally Posted by amindzo View Post
    If you use 12-bit data for SOrh, the first method in the application note is a better choice. The second method is easily implemented for 8-bit SOrh.
    Russ
  1. Calculation Problem - value goes to zero after 65
    Last Post: - 12th March 2010, 06:10
  2. how to add the calculation of temperature in my source code
    By slimpeng in forum mel PIC BASIC Pro
    Last Post: - 20th February 2008, 17:31
  3. Mathematical problem
    By iugmoh in forum General
    Last Post: - 25th January 2008, 19:24
  4. Need help with lookup table or direct calculation
    By nverma in forum mel PIC BASIC Pro
    Last Post: - 11th October 2006, 19:27
  5. Mathematical Precedence
    By keithdoxey in forum mel PIC BASIC Pro
    Last Post: - 6th October 2006, 22:44
