RF Modules
Results 1 to 40 of 45
Thread: RF Modules
    Hi Joe,
    I'm using the same power supply for both.
    I'm using a 7805 with 220uF cap and 2 diodes to lower the VCC to the transceivers.
    About the port idle state...good call
    i've set the port pins high at the beginning of the code for both ( TX and RX pics ) but the result is still the same
    Quote Originally Posted by ruijc View Post
    Hi Joe,
    Setting them high is not enough, use pullup or pulldown resistors, depending on what state is required.
    Hi Joe,
    I've placed 0.1uF caps on each transceiver VDD and GND pins.
    Also placed a resistor on the receiver side as a pullup for the RX pin.
    Still i get intermittent and incomplete data
    Hi Joe,
    OK, so then you are getting, some data. That's good. Does the receiver still fail to boot sometimes? If so, have you swapped the Tx/Rx modules to see if they both react that way? (SURE Electronics ) Seem like pretty easy to deal with vendors. Just in case there is hardware problems. If all of the above is TRUE, then I think you will need to reevaluate how you are sending data. You may need to add some character pacing scheme and or send data X # of times to insure reception.
    Are you using Tony's code exactly as published here? If not may we see what you ARE using?
    EDIT: I just loaded Tony's code . . . the half that he posted into MCS for examination . . . I hope you ARE using more than that, on account of there is no place in this where data gets loaded or stored . . . so let us see your code, please.
    Hi Joe,
    No, so far so good
    Did that...well...sort of...
    Here's the RX code
    '*  Name    : RXDemo.BAS                                        *
    '*  Notice  : Copyright (c) 2008 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 01-06-2009                                        *
    '*  Notes   : Demo for SureElectronics RF modules               *
    '*          : 16F88                                             *
        CCP1CON = %00000000         ' Disable CCP
        SSPCON.5 = 0                ' Disable SSP Module
        ANSEL = %00000000           ' Set analog ports to digital mode
        CMCON = %00000111           ' Turn off comparator
    TRISA=%00100000
    TRISB=%00000100
    'DEFINEs
    @ DEVICE PROTECT_OFF
    @ DEVICE CCPMX_OFF
    @ DEVICE DEBUG_OFF
    @ DEVICE WRT_OFF
    @ DEVICE CPD_OFF
    @ DEVICE LVP_OFF
    @ DEVICE BOD_OFF
    @ DEVICE MCLR_OFF
    @ DEVICE PWRT_ON
    @ DEVICE WDT_ON
    @ DEVICE XT_OSC
    ' DEFINE LCD pins
    DEFINE  LCD_DREG        PORTA
    DEFINE  LCD_DBIT            0
    DEFINE  LCD_RSREG       PORTB
    DEFINE  LCD_RSBIT           1
    DEFINE  LCD_EREG        PORTB
    DEFINE  LCD_EBIT            0
    DEFINE  LCD_BITS            4
    DEFINE LCD_LINES 4              ' # of Lines on LCD,  1 or 2 (Note: use 2 for 4 lines)
    DEFINE LCD_COMMANDUS 2000       'lcd delay us
    DEFINE LCD_DATAUS 50            ' Data delay time in us
    'debug defines
    INCLUDE "modedefs.bas"
    DEFINE DEBUG_REG PORTB
    DEFINE DEBUG_BIT 3
    DEFINE DEBUG_BAUD 19200
    DEFINE DEBUG_MODE 1
    define DEBUGIN_REG PORTB
    define DEBUGIN_BIT 2
    define DEBUGIN_BAUD 19200
    define DEBUGIN_MODE 1
    DEFINE DEBUG_PACING 10000
    'PINS
    adc     var          PORTA.0  '
    a1      var          PORTA.1  '
    lcd1    var          porta.2  '
    lcd2    var          porta.3  '
    freq    var          porta.4  'pin8 of transceiver
    BUT1    var          porta.5  'Button1
    xtal1   var          porta.6  '
    xtal2   var          porta.7  '
    B0      var          portb.0  '
    B1      var          portb.1  '
    RX      var 	     PORTB.2  ' out
    TX      var 	     PORTB.3  ' in
    lcd4    var          portb.4  'Data pin for LCD
    lcd5    var          portb.5  'Data pin for LCD
    lcd6    var          portb.6  'Data pin for LCD
    lcd7    var          portb.7  'Data pin for LCD
    'variables
    maximo   var        WORD	'maximum value detected
    minimo   var        WORD	'minimum value detected
    media    var        WORD	'average
    mediac   var        WORD	'total of records received - average count
    km       var        WORD	'PowerOn counter
    MA       var        WORD	'
    MI       var        WORD	'
    ps4      var        WORD	'
    value    var        WORD	'value received
    medres   var        WORD	'value sum for avg math
    ADDR     var        word
    ra       var        word
    time     var        word
    timex    var        word
    MYDATA   var        word
    'contants
    Row1  CON 128 'constant for LCD line1
    Row2  CON 192 'constant for LCD line2
    Row3  CON 148 'comstant for LCD line3
    Row4  CON 212 'constant for LCD line4
    cl    con 254 'constant for LCD clear line
    clear
    INCLUDE "lcdbarIN.bas"
    DEFINE  LCD4X20  1
    INIT:
    high tx
    high rx
    pause 400
    lcdout $fe,1,"  RX demo "
    lcdout $fe,$c0,"     ...        "
    pause 1500
    if but1=1 then
    goto chann
    man:
    lcdout cl,row1," adc ", dec value
    lcdout cl,row2," media  ", dec media
    rec:
    debugin [wait ("ok"),dec MYDATA]
    lcdout cl,row4, "received - ",dec MYDATA,"   "
    goto REC
    chann:
    low freq
    pause 50
    while but1=1
    debug $af, $20
    wend
    goto man
    and the TX code
    '*  Name    : TXDemo.BAS                                        *
    '*          : 16F88                                             *
    TRISA=%00100001
    TRISB=%00000100
    'DEFINEs
    @ DEVICE PIC16F88, HS_OSC
    @ DEVICE PIC16F88, MCLR_OFF
    @ DEVICE PIC16F88, PROTECT_OFF
    DEFINE OSC 10
    @ DEVICE PIC16F88, CPD_OFF
    @ DEVICE PIC16F88, LVP_OFF
    @ DEVICE PIC16F88, BOD_OFF
    @ DEVICE PIC16F88, PWRT_OFF
    @ DEVICE PIC16F88, WDT_OFF
    @ DEVICE PIC16F88, CCPMX_OFF
    'ADC
    DEFINE ADC_BITS 10 ' Set number of bits in result ( 8 or 10 bits )
    DEFINE ADC_CLOCK 3 ' Set clock source (3=rc)
    DEFINE ADC_SAMPLEUS 50 ' Set sampling time in uS
    ANSEL=%00000001
    ADCON1=%10000000 'no Vref - Right Justify
    ADCON0=%11000001
    ' DEFINE LCD pins
    DEFINE  LCD_DREG        PORTB
    DEFINE  LCD_DBIT            4
    DEFINE  LCD_RSREG       PORTA
    DEFINE  LCD_RSBIT           3
    DEFINE  LCD_EREG        PORTA
    DEFINE  LCD_EBIT            2
    DEFINE  LCD_BITS            4
    'debug defines
    DEFINE DEBUG_BIT 3
    DEFINE DEBUG_MODE 1
    DEFINE DEBUGIN_REG PORTB
    DEFINE DEBUGIN_BIT 2
    DEFINE DEBUGIN_BAUD 19200
    DEFINE DEBUGIN_MODE 1
    'PINS
    adc     var          PORTA.0  'analog input
    A1      var          PORTA.1  '
    lcd1    var          porta.2  '
    lcd2    var          porta.3  '
    freq    var          porta.4  'pin8 from transceiver
    BUT1    var          porta.5  'But1
    Xtal1   var          porta.6  'Xtal
    Xtal2   var          porta.7  'Xtal
    B0      var          portb.0  '
    B1      var          portb.1  '
    RX      var 	     PORTB.2  ' in
    TX      var 	     PORTB.3  ' out
    lcd3    var          portb.4  'Data pin for LCD
    lcd4    var          portb.5  'Data pin for LCD
    lcd5    var          portb.6  'Data pin for LCD
    lcd6    var          portb.7  'Data pin for LCD
    'variables
    MA       var        WORD	'
    MI       var        WORD	'
    ME       var        WORD	'
    ps4      var        WORD	'
    ADDR     var        word
    ra       var        word
    time     var        word
    timex    var        word
    MYDATA   var        word
    'contants
    p1a             con   $10
    p1b             con   $e20
    ctw             CON   $A0
    clear
    DEFINE  LCD4X20  1
    INIT:
    high rx
    high tx
    pause 400
    lcdout $fe,1,"  TX demo "
    pause 1500
    debug $55
    if but1=1 then
    goto chann
    man:
    high freq
    me=0
    for ra=0 to 15
    adcin adc,value
    pause 50
    me=me+value
    next ra
    me=me/16
    media=me
    media=(media*/5000)>>2
    transmit:
    lcdout cl,row4,"transmiting - ",dec value ,"   "
    debug $55,"ok", dec value dig 3, dec value dig 2, dec value dig 1, dec value dig 0
    goto man
    chann:
    low freq
    pause 50
    while but1=1
    debug $af, $20
    wend
    goto man
    Thanks to Joe the problem has been solved.
    The problem was related with the Mode ( debug defines ) settings.
    I changed from MODE 1 to MODE 0 and it started to receive all data 100%.
    Thanks Joe.
    idrenth's Avatar
    idrenth Guest
    Hello
    can maybe sombody give a circuit so I can test it.
    I have the CY2196R module but I didn't get it running also.
    I hope for respons.
    regards idrenth
    JulianDichiara's Avatar
    JulianDichiara Guest
    Default Answer
    I was looking for things to do with my GP-GC010. I came across this forum.
    I got my GP-GC010 working well. At first I was having the same problems as
    ruijc was having. I got mine to work with a debug window and an example
    program displaying this string "On The Air!". I'm using a 3.3 volt regulator.
    I reset it and it started working (I don't really know why!).
    Jan 2008
    Dublin, Ireland
    Ah, call it the joy of electronics!
  1. RF Modules (Zigbee)
    By Chris Barron in forum mel PIC BASIC Pro
    Last Post: - 4th March 2010, 19:28
  2. Low latency Wireless RF transceiver modules?
    By mark155 in forum General
    Last Post: - 4th March 2010, 06:20
  3. RF Transceiver modules help
    By davewanna in forum mel PIC BASIC Pro
    Last Post: - 16th May 2008, 15:54
  4. Help with CC1100 RF Modules.
    By charudatt in forum mel PIC BASIC Pro
    Last Post: - 27th November 2006, 21:58
  5. RF Modules at 433.92MHz
    By Ioannis in forum Adverts
    Last Post: - 17th October 2006, 13:36
