RF Modules
Results 1 to 40 of 45
Thread: RF Modules
    I bought them but I haven't tried them yet... Next month I'm going to test them with my application...
    I don't know if 4.24 volts is fine, maximum is 4.20 according to the manual, just in case to test, add a diode to reduce it a little.
    A few questions to rule things out:
    1) Are you enabling them? (pin 5 active low)
    2) Are you using a 1k resistor between the PIC and RX (pin 3)?
    That's all right now, it's 6:30 in the morning and I'm going to bed...
    Hi danielhr77,
    Followed your guide lines...
    Done...result is the same
    Yes...i'm using pin5 low
    I wasnt...but i just tested this also and the result is the same
    Also, i programmed on both modules the channel like:
    DEBUG $af, $20
    If you remember any other pointer for me to check i will be gratefull
    My best regards
    Hmm... Do you have the correct baudrate? There's nothing else I can think of, maybe Tony has more ideas...
    Yes...19200 on both
    I'm too without ideas.
    If someone has any suggestions i would be gratefull.
    Quote Originally Posted by ruijc View Post
    DEBUG $af, $20
    Did you Pull pin 8 low before sending data and return it to High after? And did the module respond the way the Almost_A_Data sheet said ?
    Hi Joe S. and thanks for your help,
    Yes i did...I have a led connected to each one. The modules ( after sending the channel number ) light up the leds for a second confirming the channel change.
    Are you using a max232 or similar between the transceiver and the PC or between the other transceiver and the PIC ? The PIC operates in the 8N1 True mode and should have a pull up resistor on it's line, whereas the PC operates in the 8N1 Inverted mode and requires a level shifter to make it true.
    Hi Joe S.,
    the modules are connected directly to the pics.
    One thing i noticed and i found it weird is that when turning the power on the receiver ( and always the RX - never happened to the TX ) sometimes does not start receiving ( although the TX is transmitting ).
    My workaround is to turn power off for a couple of seconds and reconnect power ( and sometimes i have to do this 2 or 3 times ).
    I changed modules, experiment board, etc and this only happens on the RX side.
    Should it be any startup procedure sequence for the RX ?
    Not sure if you mean the PIC or the transceiver. The PIC RX using HSERIN <font color=red>REQUIRES a pullup to VDD </font color>or you will get an intermittent (if at all) PIC boot. If this causes problems with the radio, you can use something to buffer the link, Tristate buffer ? I discovered this a long time back with my serial LCD project. You could "buffer" it with a simple transistor, but would then be dealing with inverted serial data.
  1. RF Modules (Zigbee)
    By Chris Barron in forum mel PIC BASIC Pro
    Last Post: - 4th March 2010, 19:28
  2. Low latency Wireless RF transceiver modules?
    By mark155 in forum General
    Last Post: - 4th March 2010, 06:20
  3. RF Transceiver modules help
    By davewanna in forum mel PIC BASIC Pro
    Last Post: - 16th May 2008, 15:54
  4. Help with CC1100 RF Modules.
    By charudatt in forum mel PIC BASIC Pro
    Last Post: - 27th November 2006, 21:58
  5. RF Modules at 433.92MHz
    By Ioannis in forum Adverts
    Last Post: - 17th October 2006, 13:36
