(what I understand from the manual).
http://www.sure-electronics.net/rf,audio/GP-GC010.pdf
The baud rate is 19200. The module has a TX buffer of 64 bytes.
When you send, the data (up to 64 bytes) is stored first in the
TX buffer of the module and then, 10ms after that the last byte
has been received, the data is automatically sent. The duration
of the transmission depends on the quality of the RF link and the
number of bytes that you have in the buffer. Use the "Busy" output
to see when the transmission task has been completed and the buffer
is ready to receive the next data packet.
The word "customizable" probably means that you can order modules
with a different baud rate in case your device is not able to
use the baud rate 19200. (Probably a minimum quantity will apply
for this special firmware).
The module can use one of 64 channels. Make sure that both modules
use the same channel.
Best regards,
Luciano
