250 ohm relay... how measure ?
Results 1 to 3 of 3
    KB3BYT's Avatar
    KB3BYT Guest
    Default 250 ohm relay... how measure ?
    I hooked up a 250 ohm coil on a OEG 5 volt relay, added EMP .. 1N4001 diode and a .01uF disc capacitor to GPIO.0 on
    a PIC12C509A.
    Relay doing 30 minute ON time and 30 minute OFF time
    with plain HIGH and LOW.
    I was trying to figure out if the PIC would burn out and tried to measure miliamps BUT my multimeter will not display any values
    at all during ON time when wired inline in the relay coil circuit.
    I swapped settings on the meter and measure 6 volts DC and the relay does CLICK.
    Perhaps my meter is not sensitive enough.
    Strictly using just one I/O line so not too worried about any 25ma
    maximums..... but I would feel better if the meter actually produced
    an acurate reading.
    Time to invest in a new meter for Christmas perhaps...
    5v divided by 250 ohms gives 20mA... well inside the 25mA individual pin limit.
    Feb 2004
    Germany
    Assuming you have handled your meter correctly, Melanie is absolutely right.
    But as any "cheap" Meter today has a at least a 2mA Range, you have probably just missed move the red wire on your meter from the "V" jacket to the "A" jacket to measure current.
    You could also have blown the Meters Fuse by trying to measure Voltage in the "Current" setting.
    regards
    Ralph
  1. Resistor Ohm Meter
    By TheMadMan in forum Schematics
    Last Post: - 14th February 2010, 20:04
  2. Need Help
    By PVBiljon in forum mel PIC BASIC Pro
    Last Post: - 29th May 2009, 18:04
  3. Replies: 24
    Last Post: - 7th November 2008, 05:41
  4. Serin to Serin2 ??
    By Gixxer in forum mel PIC BASIC Pro
    Last Post: - 25th January 2008, 04:56
  5. Serial Relays
    By tazntex in forum General
    Last Post: - 17th May 2007, 18:42
