Feeling Noobish with 12F683
Results 1 to 21 of 21
    Default same old same old
    Quote Originally Posted by picster View Post
    I'm going to try installing the latest MPLAB IDE. I'm using it as the assembler. My current version is 7.3, so we'll see if the new one makes any difference.
    Is there SOMEONE out there who can try my program on THEIR EPIC Plus with a '683 and see if it works for them?
    MPLAB updated, no change in the outcome. Still the same message.
    Try this. Insert the PIC in the EPIC DIP or ZIF socket. Start meProg software, select the
    PIC12F683, then click "Get Target Information" under the Program menu.
    Does it return "Target device matches selected device"?
    Note: Try the onboard DIP socket if it doesn't work in the ZIF.
    If yes then try this;
    With your meProg software, place a check next to "all" options under the main "Options"
    menu.
    Under "More Options" place a check by "Configuration" in Program, Verify, Read and Erase.
    If it still doesn't work, look in the help file for instructions showing how to test the output
    voltage of both onboard regulators.
    I haven't used the old parallel EPIC for years, but I had a similar problem that was fixed by
    adjusting the potentiometer that sets Vpp.
    Some PICs it would program fine. Others it wouldn't.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Default ongoing 12F683 saga
    menu.
    1) In the onboard socket, it returns a match in device.
    2) I still get the same error when I click the checkboxes as you suggest.
    3) I checked the voltages as per the help file, and they're bang-on. Did you adjust the voltage upwards, or downwards from 13.5V when you adjusted your pot?
    Mine needed adjusting up.
    -Bruce
    tech at rentron.com
    Default emailed to meLabs
    No luck. Adjusted the voltage up a bit, and down a bit. The only byte this seems to be writing is byte 0. Beyond that, it's all blank (03FF). Beats me why it's giving me the error message ABOUT location 0.
    Again, other pics (well, my trusty 16F88's) program just fine.
    Sent an email to MeLabs - if I get a resolve there, I'll post it in followup.
    Default 12F683 programming issue resolved
    Well, the MElabs folks suggested that I download the OLD version of the EPIC programmer software, version 2.46, from their website and try that to fix my problem. Lo and behold, it WORKED!!!
    So if anyone else is having this issue, programming problems with the parallel EPIC programmer and the 12F683, this seems to be the fix.
    picster
  1. 12F683 2 x PWM Outputs
    Last Post: - 23rd July 2021, 21:20
  2. 12F683 - Pin1 not working
    Last Post: - 8th February 2014, 18:38
  3. 12F683 HPWM Usage
    By MARAD75 in forum mel PIC BASIC Pro
    Last Post: - 15th November 2007, 03:16
  4. 16f677a to 12f683
    Last Post: - 25th July 2007, 07:16
  5. upgrade to PBP 2.46 and using 12F683
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2005, 08:13
