Feeling Noobish with 12F683
Results 1 to 21 of 21
    Default fuse setting in code
    Dave,
    Not sure about how to set the fuses in code, I've always done it from the EPIC programmer's chip configuration settings window because it's simple.
    I'm doing the PICBASIC in microcode studio - so if there's an easy way to set these switches there, I suppose I could try it (but right now I wouldn't know how).
    Quote Originally Posted by picster View Post
    Dave,
    This is the best explanation of how to set the fuses in code space.
    As usual, pay close attention to the post from Melanie and Mister-E.
    Is there a way in the EPIC to turn that option off? I have not used the EPIC.
    Default another kick at the can
    I'm going to try installing the latest MPLAB IDE. I'm using it as the assembler. My current version is 7.3, so we'll see if the new one makes any difference.
    Is there SOMEONE out there who can try my program on THEIR EPIC Plus with a '683 and see if it works for them?
    Default same old same old
    MPLAB updated, no change in the outcome. Still the same message.
    Try this. Insert the PIC in the EPIC DIP or ZIF socket. Start meProg software, select the
    PIC12F683, then click "Get Target Information" under the Program menu.
    Does it return "Target device matches selected device"?
    Note: Try the onboard DIP socket if it doesn't work in the ZIF.
    If yes then try this;
    With your meProg software, place a check next to "all" options under the main "Options"
    menu.
    Under "More Options" place a check by "Configuration" in Program, Verify, Read and Erase.
    If it still doesn't work, look in the help file for instructions showing how to test the output
    voltage of both onboard regulators.
    I haven't used the old parallel EPIC for years, but I had a similar problem that was fixed by
    adjusting the potentiometer that sets Vpp.
    Some PICs it would program fine. Others it wouldn't.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Default ongoing 12F683 saga
    menu.
    1) In the onboard socket, it returns a match in device.
    2) I still get the same error when I click the checkboxes as you suggest.
    3) I checked the voltages as per the help file, and they're bang-on. Did you adjust the voltage upwards, or downwards from 13.5V when you adjusted your pot?
    Mine needed adjusting up.
    -Bruce
    tech at rentron.com
  1. 12F683 2 x PWM Outputs
    Last Post: - 23rd July 2021, 20:20
  2. 12F683 - Pin1 not working
    Last Post: - 8th February 2014, 17:38
  3. 12F683 HPWM Usage
    By MARAD75 in forum mel PIC BASIC Pro
    Last Post: - 15th November 2007, 02:16
  4. 16f677a to 12f683
    Last Post: - 25th July 2007, 06:16
  5. upgrade to PBP 2.46 and using 12F683
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2005, 07:13
