Do you get the same error if you try programming the part in the EPIC DIP socket?
Haven't tried it... I'll give it a shot and let you know.
Same results in the ZIF socket and in the on-board socket.
Any other ideas? If the 16F88's wouldn't program, I'd at least have a pattern.
Also tried another 12F683, same result.
Can you post your config seetings from the inc file and the generated hex from you compiler?
I use the config settings via meProg options, not in the file itself, and have them set as follows:
Oscillator: INTOSCIO
Watchdog Timer: Disabled
PowerUp Timer: Disabled
MCLR Pin Function: Reset
Brown-out Detect: Disabled
Internal External Switchover: Disabled
Fail-Safe Clock Monitor: Disabled
Code: Not Protected
Data EEPROM: Not Protected
Here's the hex generated:
:020000040000FA
:100000002E288001840AFF3E031D01282928A30110
:10001000A200FF30A207031CA307031C29280330FA
:10002000A100DF3015200928A101E83EA000A109A8
:10003000FC30031C1E28A00703181B28A00764001F
:10004000A10F1B2820182428A01C282800002828DD
:10005000080083130313831264000800073099001B
:1000600083169F0160308F00283085002030840087
:10007000603083120120A03084002030012005165A
:100080000130A300F430082005120130A300F43041
:0400900008203F28DD
:02400E00FC3F75
:00000001FF
Do you have the program Configuration option checked?
Added: And since you are changing the configs manually, unchecking the Update Configuration From File option will make things easier. Won't help the current problem though.
Darrel,
I have the item you noted checked, and upload config from file UNchecked. I don't have "Program Fast" checked - but I doubt this would be the problem?
Maybe a bug in the 683 include file? Should I post it for comparison to yours? I haven't edited it or anything, but maybe it's a 2.46 undoc'd bug or something?
using meProg 3.30 - is there firmware for the Epic Plus parallel?
