Feeling Noobish with 12F683
Results 1 to 21 of 21
    Exclamation Feeling Noobish with 12F683
    Ok, this is getting to me.
    very simple test program:
    CMCON0=7 '00000111 - comparator pins configured as I/O
    ANSEL=0 'all I/O is digital
    OSCCON=96 'internal 4mhz clock 01100000
    TRISIO=40 '101000
    led var GPIO.4
    CLEAR
    start:
    led=1
    led=0
    goto start
    compiles fine (no duh)
    Using pbp 2.46, the parallel EPIC PLUS programmer, ICSP harness... erases fine, confirmed blank.
    I get a "code programming error at 0000"
    Upon "verify", it shows the following message:
    "Configuration verify error at 0000. 0FFF should be 00F4. Continue verifying?"
    The rest verifies ok if I click YES.
    I have verified that I can program a 16F88 right afterwards, with no issues.
    What the heck ?
    Any suggestions?
    Do you get the same error if you try programming the part in the EPIC DIP socket?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Default noobisms
    Haven't tried it... I'll give it a shot and let you know.
    Default same old same old
    Same results in the ZIF socket and in the on-board socket.
    Any other ideas? If the 16F88's wouldn't program, I'd at least have a pattern.
    Also tried another 12F683, same result.
    Contact [email protected]
    I'm sure they'll get you up & going.
    -Bruce
    tech at rentron.com
    Can you post your config seetings from the inc file and the generated hex from you compiler?
    I use the config settings via meProg options, not in the file itself, and have them set as follows:
    Oscillator: INTOSCIO
    Watchdog Timer: Disabled
    PowerUp Timer: Disabled
    MCLR Pin Function: Reset
    Brown-out Detect: Disabled
    Internal External Switchover: Disabled
    Fail-Safe Clock Monitor: Disabled
    Code: Not Protected
    Data EEPROM: Not Protected
    Here's the hex generated:
    :020000040000FA
    :100000002E288001840AFF3E031D01282928A30110
    :10001000A200FF30A207031CA307031C29280330FA
    :10002000A100DF3015200928A101E83EA000A109A8
    :10003000FC30031C1E28A00703181B28A00764001F
    :10004000A10F1B2820182428A01C282800002828DD
    :10005000080083130313831264000800073099001B
    :1000600083169F0160308F00283085002030840087
    :10007000603083120120A03084002030012005165A
    :100080000130A300F430082005120130A300F43041
    :0400900008203F28DD
    :02400E00FC3F75
    :00000001FF
    Quote Originally Posted by picster View Post
    What version of software/firmware for the EPIC PLUS are you running?
    Default more info
    using meProg 3.30 - is there firmware for the Epic Plus parallel?
  1. 12F683 2 x PWM Outputs
    Last Post: - 23rd July 2021, 21:20
  2. 12F683 - Pin1 not working
    Last Post: - 8th February 2014, 18:38
  3. 12F683 HPWM Usage
    By MARAD75 in forum mel PIC BASIC Pro
    Last Post: - 15th November 2007, 03:16
  4. 16f677a to 12f683
    Last Post: - 25th July 2007, 07:16
  5. upgrade to PBP 2.46 and using 12F683
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2005, 08:13
