Displaying temperature Setpoints
Results 1 to 40 of 59
    Looks like you removed the command to goto
    checkdone:
    Oct 2008
    Question
    but there was no command prior to this that said goto checkdone. . .
    Quote Originally Posted by Kalind View Post
    OOPPS, gettemp runs into checkdone.
    Do the relays work?
    Oct 2008
    well, i tested the relay port using a multimeter and there seems to be no voltage output when tempc>=highpt and the same goes for he highled port.
    In post #37 the code worked but was slow.
    In post #43 the outputs on PORTA does not work.
    ADCON1 and ADCON0 has been changed between the two post??
    Oct 2008
    Exclamation
    well i thought by changing the oscillator settings it would sought out th delay but obviously no change. im trying to do some code concerning high led and low led outputs. will post it by the end of today. please take a look at it and let me know if im going the right path
  1. Write Onewire data toa I2C memory / read ASCI
    By Eugeniu in forum mel PIC BASIC Pro
    Last Post: - 16th November 2008, 20:19
  2. Displaying temperature using a -40 to 185F??
    By jblackann in forum mel PIC BASIC Pro
    Last Post: - 15th January 2008, 19:45
  3. Conversion problem
    By eva in forum mel PIC BASIC Pro
    Last Post: - 15th March 2007, 19:21
  4. Help for decimal conversion
    Last Post: - 15th March 2007, 19:20
  5. Serout "onewire.bas"
    By puru in forum mel PIC BASIC Pro
    Last Post: - 6th July 2005, 01:14
