what i meant was that i removed those lines of code. now im using the following which is without the other features i was planning to implement. below is the latest code.
im realy desperate to get this thing working guys....Code:Define LCD_DREG PORTB Define LCD_DBIT 0 Define LCD_RSREG PORTB Define LCD_RSBIT 5 Define LCD_EREG PORTB Define LCD_EBIT 4 DEFINE LCD_BITS 4 DEFINE LCD_LINES 2 mode var byte keyin var byte adval var word tempc var word highpt var byte lowpt var byte highled var porta.1 lowled var porta.2 relayhigh var porta.3 relaylow var porta.4 up var portc.0 down var portc.1 sethighp var portc.2 setlowp var portc.3 maindisp var portc.4 highpt = 100 lowpt = 0 trisc= %00011111 trisa=%00000001 adcon1=%10001110 adcon0=%11000001 pause 100 lcdout $fe , 1 mode = 1 goto main getkey: pause 50 keyin = portc return gettemp: adcon0.2=1 pause 1 checkdone: if adcon0.2=1 then checkdone adval.highbyte=adresh adval.lowbyte=adresl tempc=50*adval tempc=tempc/100 If tempc>=highpt then high highled high relayhigh else low relaylow low lowled endif If tempc<=lowpt then high lowled low relaylow else low relayhigh low highled endif return main: gosub gettemp gosub getkey if maindisp = 0 then mode = 1 pause 50 if sethighp = 0 then mode = 2 pause 50 if setlowp = 0 then mode = 3 pause 50 select case mode case 1 write 0 , sethighp pause 10 write 1 , setlowp lcdout $fe , 1 Lcdout "TEMP = ",DEC tempc,$DF,"C" case 2 lcdout $fe , 1 lcdout $fe , $80 , "High Setpoint:" , $fe , $c0 , dec highpt, $DF , "C" if up = 0 then highpt = highpt + 1 pause 50 if down = 0 then highpt = highpt - 1 pause 50 if highpt>100 then highpt=100 pause 50 case 3 lcdout $fe , 1 lcdout $fe , $80 , "Low Setpoint:" , $fe , $c0 , dec lowpt, $DF , "C" if up = 0 then lowpt = lowpt + 1 if down = 0 then lowpt = lowpt - 1 if lowpt>100 then lowpt=100 end select goto main
