Displaying temperature Setpoints
Results 1 to 40 of 59
    I still see sound in that snippet and the leds are = 0 ???
    Oct 2008
    Red face
    what i meant was that i removed those lines of code. now im using the following which is without the other features i was planning to implement. below is the latest code.
    Define	LCD_DREG	PORTB
    Define	LCD_DBIT	0
    Define	LCD_RSREG	PORTB
    Define	LCD_RSBIT	5
    Define	LCD_EREG	PORTB
    Define	LCD_EBIT	4
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    mode var byte
    keyin var byte
    adval var word
    tempc var word
    highpt var byte
    lowpt var byte
    highled var porta.1
    lowled var porta.2
    relayhigh var porta.3
    relaylow var porta.4
    up var portc.0
    down var portc.1
    sethighp var portc.2
    setlowp var portc.3
    maindisp var portc.4
    highpt = 100
    lowpt = 0
    trisc= %00011111
    trisa=%00000001
    adcon1=%10001110
    adcon0=%11000001
    lcdout $fe , 1
    mode = 1
    getkey:
    pause 50
    keyin = portc
    gettemp:
        adcon0.2=1
        pause 1
    checkdone:
        if adcon0.2=1 then checkdone
        adval.highbyte=adresh
        adval.lowbyte=adresl
        tempc=50*adval
        tempc=tempc/100
        If tempc>=highpt then
            high highled
            high relayhigh
            low relaylow
            low lowled
        If tempc<=lowpt then
            high lowled
            low relaylow
            low relayhigh
            low highled
            gosub gettemp
            gosub getkey
    if maindisp = 0 then mode = 1
    pause 50
    if sethighp = 0 then mode = 2
    pause 50
    if setlowp = 0 then mode = 3
    pause 50
    select case mode
    case 1
                write 0 , sethighp
                pause 10
                write 1 , setlowp
    lcdout $fe , 1
    Lcdout "TEMP = ",DEC tempc,$DF,"C"
    case 2
    lcdout $fe , 1
    lcdout $fe , $80 , "High Setpoint:" , $fe , $c0 , dec highpt, $DF , "C"
    if up = 0 then highpt = highpt + 1
    pause 50
    if down = 0 then highpt = highpt - 1
    pause 50
    if highpt>100 then highpt=100
    pause 50
    case 3
    lcdout $fe , 1
    lcdout $fe , $80 , "Low Setpoint:" , $fe , $c0 , dec lowpt, $DF , "C"
    if up = 0 then lowpt = lowpt + 1
    if down = 0 then lowpt = lowpt - 1
    if lowpt>100 then lowpt=100
    end select
    im realy desperate to get this thing working guys....
    Looks like you removed the command to goto
    checkdone:
    Oct 2008
    Question
    but there was no command prior to this that said goto checkdone. . .
    Quote Originally Posted by Kalind View Post
    OOPPS, gettemp runs into checkdone.
    Do the relays work?
    Oct 2008
    well, i tested the relay port using a multimeter and there seems to be no voltage output when tempc>=highpt and the same goes for he highled port.
    In post #37 the code worked but was slow.
    In post #43 the outputs on PORTA does not work.
    ADCON1 and ADCON0 has been changed between the two post??
  1. Write Onewire data toa I2C memory / read ASCI
    By Eugeniu in forum mel PIC BASIC Pro
    Last Post: - 16th November 2008, 20:19
  2. Displaying temperature using a -40 to 185F??
    By jblackann in forum mel PIC BASIC Pro
    Last Post: - 15th January 2008, 19:45
  3. Conversion problem
    By eva in forum mel PIC BASIC Pro
    Last Post: - 15th March 2007, 19:21
  4. Help for decimal conversion
    Last Post: - 15th March 2007, 19:20
  5. Serout "onewire.bas"
    By puru in forum mel PIC BASIC Pro
    Last Post: - 6th July 2005, 01:14
