Displaying temperature Setpoints
Results 1 to 40 of 59
    Quote Originally Posted by kalind View Post
    less than half a second.....what r u getting at ski?
    WHAT HAPPENS EVERY TIME YOUR CODE FALLS THRU TO ONE OF THOSE FLASHING LED SUBROUTINES?
    How long does it take for each one of those subroutines to execute once they're started (i.e. Gosub'd to and returned from)?
    It happens on each time around the loop after the temperature has exceeded the set point.
    How fast can your buttons/lcd/the-rest-of-the-program possibly run if it's tied up in a pause for 700ms on each run through the loop.
    JEEZE MAN!!! READ THRU YOUR OWN CODE FOR ONCE!!!! What did you do? Cut and paste this from somewhere else? How about getting your FRIEND to help you out more...if this friend actually exists...you know, the same one that HELPED you with those buttons earlier...
    Screw it...I'm done...really...this is about as annoying and frustrating as it can possibly get...the only thing that could be worse would be if your name/handle was TED's, but then again, that was more funny than annoying.
    Oct 2008
    It's for the same reason that I removed those two routines and decided to just make those pins high instead. the same thing happens...
    Quote Originally Posted by Kalind View Post
    I tried, in one last vain attempt to draw your attention to something that might be slowing down your whole project.
    But, I can see that I've failed again, because you've failed AGAIN...or maybe just YOU have FAILED to READ your OWN code...AGAIN!
    You don't think those 2 SOUND statements, with their ~3 seconds of sound making might not have anything to do with anything?
    Ok, now I'm done... Some people you just can't prod into looking at their own stuff closer...because it's all good. Of course it's all good...they wrote it...how can they possibly be wrong or mistaken about anything? Their logic is great...it flows in the code just like it does in their minds...Or does it?!?!?!?!!!!????
    Why don't you go ask your instructor for advise... You've got 48 hours...
    Oct 2008
    Question
    ski, i removed both of those flashing routines and the problem was still there. then i removed the SOUND statements aswel. seemed to have sorted out the lag issue. the problem is that now i have only a high led and low led when the setpoints are reached but thats not even working
    checkdone:
    if adcon0.2=1 then checkdone
    adval.highbyte=adresh
    adval.lowbyte=adresl
    tempc=50*adval
    tempc=tempc/100
    If tempc>=highpt then
    gosub high_flash
    SOUND buzzer, [60, 100, 23, 200]
    relayhigh = 1
    relaylow = 0
    lowled = 0
    buzzer = 0
    If tempc<=lowpt then
    gosub low_flash
    SOUND buzzer, [20, 100, 23, 200]
    relaylow = 1
    relayhigh = 0
    highled = 0
    buzzer = 0
    I still see sound in that snippet and the leds are = 0 ???
    Oct 2008
    Red face
    what i meant was that i removed those lines of code. now im using the following which is without the other features i was planning to implement. below is the latest code.
    Define	LCD_DREG	PORTB
    Define	LCD_DBIT	0
    Define	LCD_RSREG	PORTB
    Define	LCD_RSBIT	5
    Define	LCD_EREG	PORTB
    Define	LCD_EBIT	4
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    mode var byte
    keyin var byte
    adval var word
    tempc var word
    highpt var byte
    lowpt var byte
    highled var porta.1
    lowled var porta.2
    relayhigh var porta.3
    relaylow var porta.4
    up var portc.0
    down var portc.1
    sethighp var portc.2
    setlowp var portc.3
    maindisp var portc.4
    highpt = 100
    lowpt = 0
    trisc= %00011111
    trisa=%00000001
    adcon1=%10001110
    adcon0=%11000001
    lcdout $fe , 1
    mode = 1
    getkey:
    pause 50
    keyin = portc
    gettemp:
        adcon0.2=1
        pause 1
    checkdone:
        tempc=50*adval
        tempc=tempc/100
            high highled
            high relayhigh
            low relaylow
            low lowled
            high lowled
            low relaylow
            low relayhigh
            low highled
            gosub gettemp
            gosub getkey
    if maindisp = 0 then mode = 1
    pause 50
    if sethighp = 0 then mode = 2
    pause 50
    if setlowp = 0 then mode = 3
    pause 50
    select case mode
    case 1
                write 0 , sethighp
                pause 10
                write 1 , setlowp
    lcdout $fe , 1
    Lcdout "TEMP = ",DEC tempc,$DF,"C"
    case 2
    lcdout $fe , 1
    lcdout $fe , $80 , "High Setpoint:" , $fe , $c0 , dec highpt, $DF , "C"
    if up = 0 then highpt = highpt + 1
    pause 50
    if down = 0 then highpt = highpt - 1
    pause 50
    if highpt>100 then highpt=100
    pause 50
    case 3
    lcdout $fe , 1
    lcdout $fe , $80 , "Low Setpoint:" , $fe , $c0 , dec lowpt, $DF , "C"
    if up = 0 then lowpt = lowpt + 1
    if down = 0 then lowpt = lowpt - 1
    if lowpt>100 then lowpt=100
    end select
    im realy desperate to get this thing working guys....
    Looks like you removed the command to goto
    checkdone:
  1. Write Onewire data toa I2C memory / read ASCI
    By Eugeniu in forum mel PIC BASIC Pro
    Last Post: - 16th November 2008, 20:19
  2. Displaying temperature using a -40 to 185F??
    By jblackann in forum mel PIC BASIC Pro
    Last Post: - 15th January 2008, 19:45
  3. Conversion problem
    By eva in forum mel PIC BASIC Pro
    Last Post: - 15th March 2007, 19:21
  4. Help for decimal conversion
    Last Post: - 15th March 2007, 19:20
  5. Serout "onewire.bas"
    By puru in forum mel PIC BASIC Pro
    Last Post: - 6th July 2005, 01:14
