Displaying temperature Setpoints
Results 1 to 40 of 59
    Quote Originally Posted by Kalind View Post
    well, this is what i managed to do.
    Looks like it's pretty much what I managed to do...
    i hooked it up to my circuit but the program isnt doing what i wanted it to do.
    It might help for you to tell us exactly what it IS or isn't doing...
    Oct 2008
    Unhappy
    taking your advice with the program, i hooked it up and on the lcd it prompts the user to enter a LOW SP. upon the use of the increment decrement buttons, on the second line of the lcd are characters which are being displayed. when the 'main' button is pressed, it does not go to the main display and also when the HighSp button is pressed, it does not go to that screen. im so lost with this whole thing
    May 2008
    Italy
    Put yours subrouteenes at the end of your code, never at the beginning!
    Modify your If then in the following manner:
    if maindisp = 1 then
    write 0 , sethighp
    pause 10
    write 1 , sethighp
    mode = 1
    maindisp = 0 ' reset flag
    Otherwise it will write at every cycle and in this case you do not need the " IF Then " statement. Set your flag to 1 when writing is needed
    Yours code for reading key:
    getkey:
    pause 50
    keyin = portc
    You read the status of the all 8 inputs, than you need to decode to find which key has been pressed.
    More:
    Are you pulling up your inputs using normally closed switches? otherwise with this code you have to pull down your inputs.
    Al.
    Quote Originally Posted by aratti View Post
    Disagree 100%, ok maybe 99%
    If using a PIC16 (or 12,or 10) series PIC, if you are able to keep the 'subroutines' in the first bank of code space, you'll save code space due to the fact that the BANK Select registers don't need to be changed, and at the same time save instruction cycles. And if your subroutines are at the beginning, they're the first thing to get seen while skimming thru the code, makes them harder to forget them (I guess more of a brain thing there).
    At any rate, there's one more small bug in your If/Then correction above (post #13)...a small one...actually two small bugs...one matters, the other doesn't really matter...
    Ok, are you sure all of your buttons are working properly?
    Oct 2008
    yup. They connected from +5v to ground using a 10K
    No, what I mean is, how do you know the PIC and/or your code is actually recognizing the buttons as pressed or not-pressed.
    Again, just 'cause you want it doesn't mean it...
    And what do you mean from +5v to ground using 10K? Leaves a bit to the imagination...
    Oct 2008
    check the button pic. that is how i connected it ski
    button pic...hmmm...what button pic?
  1. Write Onewire data toa I2C memory / read ASCI
    By Eugeniu in forum mel PIC BASIC Pro
    Last Post: - 16th November 2008, 20:19
  2. Displaying temperature using a -40 to 185F??
    By jblackann in forum mel PIC BASIC Pro
    Last Post: - 15th January 2008, 19:45
  3. Conversion problem
    By eva in forum mel PIC BASIC Pro
    Last Post: - 15th March 2007, 19:21
  4. Help for decimal conversion
    Last Post: - 15th March 2007, 19:20
  5. Serout "onewire.bas"
    By puru in forum mel PIC BASIC Pro
    Last Post: - 6th July 2005, 01:14
