Displaying temperature Setpoints
Results 1 to 40 of 59
    Now, I'll admit, sometimes there's only one way to do something, and sometimes there are hundreds of ways of doing something...but...
    http://www.picbasic.co.uk/forum/show...ight=down_loop
    See anything in there?
    There goes the benefit of doubt.
    Oct 2008
    what's post #3 all about ski? Im using a 16f873.
    Quote Originally Posted by Kalind View Post
    Wow....first I've seen of it here...unlike those other 6 threads...
    Oct 2008
    Exclamation
    well, this is what i managed to do. i hooked it up to my circuit but the program isnt doing what i wanted it to do. Skimask?
    /code
    Define LCD_DREG PORTB
    Define LCD_DBIT 0
    Define LCD_RSREG PORTB
    Define LCD_RSBIT 5
    Define LCD_EREG PORTB
    Define LCD_EBIT 4
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    mode var byte
    keyin var byte
    adval var word
    tempc var word
    highpt var byte
    lowpt var byte
    up var portc.0
    down var portc.1
    sethighp var portc.2
    setlowp var portc.3
    maindisp var portc.4
    trisc=$ff
    trisa=$ff
    adcon1=$82
    adcon0=$c1
    mode = 1
    lcdout $fe , 1
    getkey:
    pause 50
    keyin = portc
    gettemp:
    adcon0.2=1
    pause 1
    checkdone:
    if adcon0.2=1 then checkdone
    adval.highbyte=adresh
    adval.lowbyte=adresl
    tempc=(50*adval)/100
    gosub gettemp
    gosub getkey
    'saving part
    if maindisp = 1 then
    write 0 , sethighp
    pause 10
    write 1 , sethighp
    mode = 1
    if sethighp = 1 then mode = 2
    if setlowp = 1 then mode = 3
    select case mode
    case 1
    lcdout $fe , $80 , "Temp = ", DEC3 tempc , $DF , "C"
    case 2
    lcdout $fe , $80 , "High Sp=" , $fe , $c0 , highpt
    if up = 1 then highpt = highpt + 1
    if down = 1 then highpt = highpt - 1
    case 3
    lcdout $fe , $80 , "Low Pt=" , $fe , $c0 , lowpt
    if up = 1 then lowpt = lowpt + 1
    if down = 1 then lowpt = lowpt - 1
    end select
    Looks like it's pretty much what I managed to do...
    It might help for you to tell us exactly what it IS or isn't doing...
    Oct 2008
    Unhappy
    taking your advice with the program, i hooked it up and on the lcd it prompts the user to enter a LOW SP. upon the use of the increment decrement buttons, on the second line of the lcd are characters which are being displayed. when the 'main' button is pressed, it does not go to the main display and also when the HighSp button is pressed, it does not go to that screen. im so lost with this whole thing
    May 2008
    Italy
    Put yours subrouteenes at the end of your code, never at the beginning!
    Modify your If then in the following manner:
    write 0 , sethighp
    pause 10
    write 1 , sethighp
    mode = 1
    maindisp = 0 ' reset flag
    Otherwise it will write at every cycle and in this case you do not need the " IF Then " statement. Set your flag to 1 when writing is needed
    Yours code for reading key:
    getkey:
    pause 50
    keyin = portc
    You read the status of the all 8 inputs, than you need to decode to find which key has been pressed.
    More:
    Are you pulling up your inputs using normally closed switches? otherwise with this code you have to pull down your inputs.
    Al.
    Ok, are you sure all of your buttons are working properly?
    Humour me for a bit...
    Define	LCD_DBIT	0
    Define	LCD_RSBIT	5
    Define	LCD_EBIT	4
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    keyin var byte : trisc=$ff : pause 1000 : lcdout $fe,1
    main:   keyin = portc : lcdout $fe, $80, BIN8 keyin : goto main
    Push the buttons, what happens?
    Oct 2008
    should display binary number
    And does it?
  1. Write Onewire data toa I2C memory / read ASCI
    By Eugeniu in forum mel PIC BASIC Pro
    Last Post: - 16th November 2008, 20:19
  2. Displaying temperature using a -40 to 185F??
    By jblackann in forum mel PIC BASIC Pro
    Last Post: - 15th January 2008, 19:45
  3. Conversion problem
    By eva in forum mel PIC BASIC Pro
    Last Post: - 15th March 2007, 19:21
  4. Help for decimal conversion
    Last Post: - 15th March 2007, 19:20
  5. Serout "onewire.bas"
    By puru in forum mel PIC BASIC Pro
    Last Post: - 6th July 2005, 01:14
