Gpio ? Trisio ?
Results 1 to 6 of 6
Thread: Gpio ? Trisio ?
    Apr 2006
    GearSweaterMountain, The Netherlands
    Unhappy Gpio ? Trisio ?
    Hi there,
    I'm kind of stuck on this. A few weeks ago i made a RC5 IR to 10F202 receiver. All
    worked fine. I decided that i need to store some counter values in eeprom, since the
    10F does not have that, i decided to go with the 12F519.
    I was used to set the IO functionality for the 10F trough the GPIO and TRISIO registers:
    TRISIO = %00001000          'GPIO.3 = input only
    GPIO    = %00000000          'All low
    In the 12F519 datasheet is says the tri-state register is called TRISGPIO and the GPIO register is called GPIO.
    When i use TRISGPIO i get an syntax error, using TRIS or TRISIO also.
    When i set a pin like: SDA VAR GPIO.1 i get an error : undefined symbol 'GPIO'
    What am i missing ?
    Apr 2006
    I think i figured it out, but i'm still confused ...
    When i compile :
    TRISB   = %00111100                                      'Set TRIS register input's & output's
    PORTB   = %00000000                                      'Set all digital low
    SDA     var PORTB.0                                      'I2C DATA pin
    SCL     var PORTB.1                                      'I2C CLOCK pin
    It compiles, without any errors !
    How ?
    Jan 2006
    Istanbul
    Change your PIC type to 12F519 in the menu above the program.
    ______________________
    Apr 2006
    Thought of that, checked just yet it is 12F519 ... So that's not it ....
    Wink The truth ...
    The truth is always Here :
    '*  12F519.BAS                                                  *
    '*  By        : Leonard Zerman, Jeff Schmoyer                   *
    '*  Notice    : Copyright (c) 2007 microEngineering Labs, Inc.  *
    '*              All Rights Reserved                             *
    '*  Date      : 06/26/07                                        *
    '*  Version   : 2.50                                            *
    '*  Notes     :                                                 *
    BANK0   $0007, $001F
    BANK1   $0030, $003F
    EEPROM  $0400, $043F
    LIBRARY "PBPPIC12"
    DEFINE  CODE_SIZE 400h
            include "PIC12EXT.BAS"
    TRISB	VAR	BYTE BANK0 SYSTEM	' TRISB shadow register
    PORTL   VAR     PORTB
    PORTH   VAR     PORTB
    TRISL   VAR     TRISB
    TRISH   VAR     TRISB
            include "PBPPIC12.RAM"
    '*----------------------* EOF 12F519.BAS *----------------------*
    Have a look to the "1xYzzz".bas file in your PBP Directory. ( 1xYzzz = 12F519, here )
    You can modify it or add Other Aliases ... at your own risks !
    for 10F :
    '*  10F206.BAS                                                  *
    '*  Notice    : Copyright (c) 2004 microEngineering Labs, Inc.  *
    '*  Date      : 06/04/04                                        *
    '*  Version   : 2.46                                            *
    '*  Notes     :                                                 *
    BANK0   $0008, $001F
    LIBRARY "PBPPIC12"
    DEFINE  CODE_SIZE 200h
    TRISIO	VAR	BYTE BANK0 SYSTEM	' TRISIO shadow register
    PORTL   VAR     GPIO
    PORTH   VAR     GPIO
    TRISL   VAR     TRISIO
    TRISH   VAR     TRISIO
    '*----------------------* EOF 10F206.BAS *----------------------*
    Apr 2006
    You're so right !
    Thanks, all clear now !
  1. Random output upon TRISIO setup on '683
    By picster in forum mel PIC BASIC Pro
    Last Post: - 6th July 2009, 13:34
  2. 12F675 A/D and GPIO sleep interrupt
    By macinug in forum mel PIC BASIC Pro
    Last Post: - 8th September 2008, 14:39
  3. Pic12f683, Trisio, High Z, A2d
    By jmbanales21485 in forum Schematics
    Last Post: - 5th July 2007, 19:34
  4. can't even flash an LED
    By bruno333 in forum mel PIC BASIC Pro
    Last Post: - 28th April 2005, 13:27
  5. 12c508 Gpio
    By oki_one in forum mel PIC BASIC Pro
    Last Post: - 26th August 2003, 07:51
