Use Portc.1 or Portc.2 and HPWM (see page 73 of the manual)
B0 var Byte
Vduty var Byte
Vduty=0
B0=1
if UpButton =0 then
If Vduty<255 Then Vduty=Vduty+B0
Gosub HpwmSet
if DownButton =0 then
If Vduty>0 then Vduty=Vduty+B0
Gosub HpwmSet
goto Main
HpwmSet:
HPWM Channel, Vduty,Frequency
with B0 = 1 you have 255 steps , if you want 10 steps set B0 = 25
UpButton and DownButton are two input ports with a 10K resistor pullup, the switch is normally open.
Al.
Sorry should be:
If Vduty>0 then Vduty=Vduty-B0
Gosub HpwmSet
Hi all, no luck, Please gothru my code...Thanks.
Include "MODEDEFS.BAS" ' Include Shiftin/out modes
@ device PIC16F877A , xt_osc, wdt_on, pwrt_on, protect_on ,lvp_off
Define Osc 4 ' using a 4 MHz oscillator
; 76543210
TRISA = %00000000 ' ALL OUTPUTS
TRISB = %11111111 ' ALL INPUTS- KEYBRD
TRISC = %11110001 '
OPTION_REG.7=0 'Enable internal pull-ups
OPTION_REG = %11111000 ' Assign prescaller to WDT
TRISA = 0 ' Set PORTA as output
T1CON.1 = 0 ' Set TIMER1 clock source to internal clock
INTCON = %01000000 ' Enable peripheral interrupts
PIE1 = %00000001 ' Enable TMR1 overflow interrupt
CCP1CON=%00001100 ' PWM MODE
UpButton Var PORTB.0
DownButton var PORTB.1
PWMOut Var PORTC.1 ' PWM Output
DEFINE CCP1_REG PORTC 'Hpwm 1 pin port
DEFINE CCP1_BIT 2 'Hpwm 1 pin bit
DEFINE HPWM2_TIMER 1 'Hpwm 2 timer select
B0 var Byte
Vduty var Byte
Vduty=0
B0=1
if UpButton =0 then
Gosub HpwmSet
Gosub HpwmSet
goto Main
HpwmSet:
HPWM 1,25,1000 '4.00khz
'HPWM 1,25,250 '16.00khz. tried this also.
Do you have a couple of LEDs handy?
I always add a 'heart beat' LED to whatever I'm doing, even if I know the hardware is working... Really helps for troubleshooting...
And if you're using the internal pullups, you're turning on the internal pull-ups, then turning them right back off...
Code:OPTION_REG.7=0 'Enable internal pull-ups OPTION_REG = %11111000 ' Assign prescaller to WDT
naga
Go back to your post #17
In it you are changing a variable Vduty. This part is good.
You then call a subroutine HpwmSet. Explain to me how in your code Vduty changes the HPWM setting?
Go to the PICBASIC manual, look up HPWM and how it is used, an then install Vduty correctly so it actually changes your PWM setting.
