naga
If you use a PIC with Hardware PWM (eg 16F628) then varying the Duty in steps of 10% from 0 to 100% (see HPWM command) will give you your ten steps. A simple filter on the output will then give you ten voltage steps from 0v (0%) to 5v (100%).
I recall posting a circuit for an Op-Amp Voltage Doubler some time back. Do a forum SEARCH, stick that on the end of your filter and presto - you got ten steps of 0-10v.
