0-10v dc
Results 1 to 25 of 25
Thread: 0-10v dc
    Sep 2006
    Default 0-10v dc
    Hi All,
    I need a 0-10v Dc control voltage for control an electronic ballast.
    using an Op Amp and a PIC PWM output, (16f77,4mhz)
    i need to control 0-10v in 10steps with UP and Down Buttons..
    Please help..
    Thanks.
    May 2008
    Italy
    Try the attached schematic. Apply pwm to Vin. With trail and error adjust pwm to output the disired voltage. Then enter these values in your code.
    Al.
    skimask's Avatar
    skimask Guest
    Al.
    What code? I think the O/P wants the code written for them...
    With that schematic, a digital pot, a voltage divider, an A/D input, and a bit of trickery, a person should be able to hook up a PIC to auto-track/correct the output voltage...
    That's a handy little idea to have around...
    Sep 2006
    Deleted.. Sorry.
    Sep 2006
    Dude! I agree that you are a genius, but i am Just a learner.. support ppl who wants some help but dont try to stop who willing to help..
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by naga View Post
    Ok, fact #1 - I'm no genius...
    fact #2 - good luck getting your code to compile and work in MeLabs PicBasicPro (any version)
    And...that code you posted...why would it stop for you? There's nothing in there to make it stop!
    Sep 2006
    Thank you very Much, actually i was trying that code in proton,by mistake i pasted.will delete now.
    Since you are a senior member of this forum, and you also understood what code i am searching for, Could you pls help me out. i need to adjust the voltage 0-10 with 2 buttons..
    Help would be appritiated..
    Warm Regards..
    skimask's Avatar
    skimask Guest
    Warm Regards..
    Again...not a senior member of anything, and I don't use Proton.
    That code you copied was close...so, change it to fit PBP.
    OK, the 555 is good trick, but if you use an LMC66x series op-amp and a single +12 volt supply, you have a 0-10 voltage amplifier with 3 parts! May be 2 more to filter PWM from PIC...
    naga
    If you use a PIC with Hardware PWM (eg 16F628) then varying the Duty in steps of 10% from 0 to 100% (see HPWM command) will give you your ten steps. A simple filter on the output will then give you ten voltage steps from 0v (0%) to 5v (100%).
    I recall posting a circuit for an Op-Amp Voltage Doubler some time back. Do a forum SEARCH, stick that on the end of your filter and presto - you got ten steps of 0-10v.
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by Melanie View Post
    http://www.picbasic.co.uk/forum/show...hlight=doubler
    Is that it? I've got it on my 'hot' list of handy items to keep around...
    May 2007
    Or you could use one of these (without the need for a separate high voltage supply):
    http://www.microchip.com/wwwproducts...cName=en010581
    The TCM828/829 are CMOS "charge-pump" voltage converters in ultra-small 5-Pin SOT-23A packages. They invert and/or double an input voltage which can range from +1.5V to +5.5V. Conversion efficiency is typically >95%. Switching frequency is 12kHz for the TCM828 and 35kHz for the TCM829. External component requirement is only two capacitors (3.3µF nominal) for standard voltage inverter applications. With a few additional components a positive doubler can also be built. All other circuitry, including control, oscillator, power MOSFETs are integrated on-chip. Supply current is 50µA (TCM828) and 115µA (TCM829). The TCM828 and TCM829 are available in a 5-Pin SOT-23A surface mount package.
    Sep 2006
    naga
    Hi, Could you please guide me If a 4MHz oscillator and 16f877a are used. want to control with UP and Down Buttons(10 steps)
    Example: (Porta.0)
    PWM PORTA.0,127,10 ?
    Thank you.
    May 2008
    Italy
    Use Portc.1 or Portc.2 and HPWM (see page 73 of the manual)
    B0 var Byte
    Vduty var Byte
    Vduty=0
    B0=1
    if UpButton =0 then
    If Vduty<255 Then Vduty=Vduty+B0
    Gosub HpwmSet
    if DownButton =0 then
    If Vduty>0 then Vduty=Vduty+B0
    Gosub HpwmSet
    goto Main
    HpwmSet:
    HPWM Channel, Vduty,Frequency
    with B0 = 1 you have 255 steps , if you want 10 steps set B0 = 25
    UpButton and DownButton are two input ports with a 10K resistor pullup, the switch is normally open.
    Al.
    May 2008
    Italy
    Sorry should be:
    If Vduty>0 then Vduty=Vduty-B0
    Gosub HpwmSet
    skimask's Avatar
    skimask Guest
    Sorry should be:
    Gosub HpwmSet
    You know you can EDIT your own posts right?
    Look down by the QUOTE button after you've submitted your post.
    Sep 2006
    Sorry should be:
    Gosub HpwmSet
    Hi all, no luck, Please gothru my code...Thanks.
    Include "MODEDEFS.BAS" ' Include Shiftin/out modes
    @ device PIC16F877A , xt_osc, wdt_on, pwrt_on, protect_on ,lvp_off
    Define Osc 4 ' using a 4 MHz oscillator
    ; 76543210
    TRISA = %00000000 ' ALL OUTPUTS
    TRISB = %11111111 ' ALL INPUTS- KEYBRD
    TRISC = %11110001 '
    OPTION_REG.7=0 'Enable internal pull-ups
    OPTION_REG = %11111000 ' Assign prescaller to WDT
    TRISA = 0 ' Set PORTA as output
    T1CON.1 = 0 ' Set TIMER1 clock source to internal clock
    INTCON = %01000000 ' Enable peripheral interrupts
    PIE1 = %00000001 ' Enable TMR1 overflow interrupt
    CCP1CON=%00001100 ' PWM MODE
    UpButton Var PORTB.0
    DownButton var PORTB.1
    PWMOut Var PORTC.1 ' PWM Output
    DEFINE CCP1_REG PORTC 'Hpwm 1 pin port
    DEFINE CCP1_BIT 2 'Hpwm 1 pin bit
    DEFINE HPWM2_TIMER 1 'Hpwm 2 timer select
    B0 var Byte
    Vduty var Byte
    Vduty=0
    B0=1
    if UpButton =0 then
    Gosub HpwmSet
    Gosub HpwmSet
    goto Main
    HpwmSet:
    HPWM 1,25,1000 '4.00khz
    'HPWM 1,25,250 '16.00khz. tried this also.
    skimask's Avatar
    skimask Guest
    Do you have a couple of LEDs handy?
    I always add a 'heart beat' LED to whatever I'm doing, even if I know the hardware is working... Really helps for troubleshooting...
    And if you're using the internal pullups, you're turning on the internal pull-ups, then turning them right back off...
    Sep 2006
    Hi, Still not working..need help..
    Thanks.
    naga
    Go back to your post #17
    In it you are changing a variable Vduty. This part is good.
    You then call a subroutine HpwmSet. Explain to me how in your code Vduty changes the HPWM setting?
    Go to the PICBASIC manual, look up HPWM and how it is used, an then install Vduty correctly so it actually changes your PWM setting.
    Sep 2006
    naga
    @Melanie, Should i change " HPWM 1,25,1000" TO " HPWM 1,127,1000" ? as per the PBPManual. And please let me know if any other value needs to be changed.. Actaully i'll have to finish this project as soon as possible..
    Thank you verymuch..
    skimask's Avatar
    skimask Guest
    What Melanie meant was to examine this piece of code:
    HpwmSet:
    1 is a constant, 25 is a constant, 1000 is a constant.
    If the values in the HPWM statement are all constants, how is a variable in your main loop supposed to change that constant?
    If you change
    HPWM 1,25,1000
    to
    HPWM 1,127,1000
    all you've done is change the 25 to a 127.
    So, WHAT in your code is going to change ANYTHING in your HPWMset subroutine?
    May 2008
    Italy
    Naga the solution is under your eyes. With the present code you can press the switches for all your life but the duty cycle of your pwm out will remain always 25! Why we are making the variable VDuty moving from 0 to 255. Why I told you to change B0 to 25 if you want to scan the whole range with 10 steps ?
    Al.
    Sep 2006
    Al.
    Hi all,So in my post #17, which Part of a statement that is not correct..Help.
    Come on naga, are kidding us?
    Where in the
    are setting the duty?
    Put the variable Vduty in the HPWM statement... (instead of number 25) like this:
    HPWM 1,Vduty,1000 '4.00khz
  1. DC to AC convertor
    Last Post: - 6th February 2010, 18:44
  2. Replies: 24
    Last Post: - 1st December 2009, 09:01
  3. from 5v dc to 1.00v dc precise vref 10mA ?
    By phoenix_1 in forum Schematics
    Last Post: - 28th July 2009, 09:11
  4. PIC data along dc line
    By sswcharlie in forum General
    Last Post: - 30th August 2008, 09:38
  5. H-Bridge control DC motor
    By Paul F in forum General
    Last Post: - 2nd March 2005, 22:04
