Sorry I have forgotten a Dec. Please read......
LCDOUT $FE, $C0, DEC ByteInteger,",",DEC ByteDecimal
Dear MEN !
I do not use a LCD display . I have make only a comparision .
I use in front of my program this line to write text "
I2Cwrite I2CDAT, I2CCLK, $A0, adr,[" Temperature is _________________ "]
late in program , in free space I wish to write DATA of temperature
adr = 15( where is free space )
I2Cread I2CDAT, I2CCLK, $A0, adr,[ temperature DATA ]
In finish, I wish to can read all - text and temperature DATA as ASCI CODE such as
Temperatura is 25,55(for example) .
from this formula :
i2cread I2CDAT , I2CCLK , $A0,J,[caracter]
program read for every adrress (j) a sign (caracter ) in ASCI Code , and this CODE i'll translate in leds on .But where I write temperature DATA , program read other signs not ASCI CODE for 25,55 ( for example )
Now understand me ?
I 'll try to write only text with quote and temperature DATA except quote
I assume you have grounded pin 1 , pin 2 and pin 3 of your 24LC01 chip and that you have pulled up pin 6 and pin 5 with a 4.7K resistors (see page 85 of the manual)
Just use the following code:
'set these variable
WriteDev con %10100000
ReadDev con %10100001
Celsius VAR BYTE [32]
Fix text in the array
Celsius[0]=84
Celsius[1]=101
Celsius[2]=109
Celsius[3]=112
Celsius[4]=101
Celsius[5]=114
Celsius[6]=97
Celsius[7]=116
Celsius[8]=117
Celsius[9]=114
Celsius[10]=32
Celsius[11]=105
Celsius[12]=115
Celsius[13]=32
Celsius[14]=0
Celsius[15]=44
Celsius[16]=0
Now in your program you read temperature from your device and you have the value in the variable TEMPERATURE!
write:
Celsius[14] = TEMPERATURE/100
Celsius[16] = TEMPERATURE - (Celsius[14]*100)
So you will have the integer part of your value in Celsius[14] and the decimal part in Celsius[16]. Celsius[15]=44 is your separator.
Now write to your memory at address 0
adr=0
I2CWRITE I2CDAT, I2CCLK, WriteDev , adr,[ Str Celsius\32]
PAUSE 10
Now if your hardware works properly, you should have stored in your memory the string and the values.
To recall them back:
adr=0
I2CREAD I2CDAT, I2CCLK, ReadDev , adr,[ Str Celsius\32]
Pause 10
At this point you send the array to your display
For A0=0 to 16
single byte (Celsius[A0]) can be sent to your display
Next A0
If you need to store more than on single value you have to increment your Address (adr) by a multiple of 32, and with two values you have filled one page (64 bytes)
Al.
QUOTE=aratti;
I use this display NOW , and scroll a simple text , but a long text , what is writing in a 24FC512 menory . It has pins 1,2,3,4 and 7 to ground .
'set these variable
What doing this ?
I use a long text ......with caps.letters only ( you can see this in my programe ).
Celsius[0]=84 = T
Celsius[1]=101 = e
Celsius[2]=109 = m
Celsius[3]=112 = p
Celsius[4]=101 = e
Celsius[5]=114 = r
Celsius[6]=97 = a
Celsius[7]=116 = t
Celsius[8]=117 =u
Celsius[9]=114 =r
Celsius[10]=32 = blank
Celsius[11]=105 = i
Celsius[12]=115 = s
Celsius[13]=32 = blank
Celsius[14]=0 this is not 0
Celsius[15]=44 = ,
Celsius[16]=0
write:
adr=0
PAUSE 10
Look back in message , I must to use only this formula , only one .
I2Cread I2CDAT , I2CCLK , $A0 , J ,[caracter]
adr=0
Pause 10
For A0=0 to 16
Next A0
Thank you !
Either there is still a serious language barrier here or you're not getting what we're trying to say... In either case, I wish I spoke whatever language you speak so we could get this all straightened out a lot faster...
And is it working the way you want it to work?I use this display NOW , and scroll a simple text , but a long text , what is writing in a 24FC512 menory . It has pins 1,2,3,4 and 7 to ground .
Shouldn't have to use 2 different 'codes' for reading and writing to an I2C eeprom. PBP handles the Read/Write bit (bit0 in the 'code') for you. Should only need to use $A0 when addressing a standard 24xxxxx serial eeprom.What doing this ?
Are you storing the entire string, along with the temperature data in the eeprom or just the temperature?I use a long text....with caps.letters only (you can see this in my programe)
That may be so, but to store a temperature, with a whole part and a fractional part, along with any other characters, you are going to need more than one byte of storage and will need more than one I2CWRITE command...Look back in message , I must to use only this formula , only one .
skimask;64321 Either there is still a serious language barrier here or you're not getting what we're trying to say... In either case, I wish I spoke whatever language you speak so we could get this all straightened out a lot faster...
I am from Bucharest , ROMANIA .
It work OK with a simle text . But I wish to add in the fututre more options such : temperature out , temperature in house , time , date ...
Of course , I use this " $A0 "
I wish to store only result ( I think that I understand exactly what you say ??)
Is not important how many I2Cwrite command will be use ,if PIC16F876 support lenght of code . Important is to can used only one command I2Cread to read all - text and data -
Those 2 comments contradict themselves...Is not important how many I2Cwrite command will be use ,if PIC16F876 support lenght of code . Important is to can used only one command I2Cread to read all - text and data
-----Is not important how many I2CWRITE command will be use, if PIC support length of code----
Tells me that you can use I2CWRITE as many times as you need as long as the PIC has enough code space left...
----Important is to can used only one command I2CREAD to read all - text and data -----
Tells me that you MUST read everything you write with one single command.
Which one is it?
