Write Onewire data toa I2C memory / read ASCI
Results 1 to 40 of 68
    Nov 2007
    Just exactly what you had...
    i2cwrite I2CDAT, I2CCLK, $A0, adr,[Byte_integer,Byte_decimal]
    Then read them back the same way and display them on the LCD seperately with a decimal point in between them.
    I do not use LCD , I use a 7 X 96 leds panel . With LCD is very simple ! Support all of these "DEC DIG HEX BIN,"
    Quote Originally Posted by Eugeniu View Post
    Ahhh....ok....I see now...
    Well then...your answer is in post #2...
    Nov 2007
    I am sorry ! but I do not see in mind the solution for my problem .
    I say again : PLEASE ! SHOW ME IN CONTEXT EXAMPLE , in my programme.
    Ok, you can't display a byte variable directly because a byte (if larger than 9) contains more than one numeric character right?
    Nov 2007
    I must to read from memory , for example :for 25,55 (grade C ) I must to read from memory ...50 53 44 53 53 , or except " , " 50 53 53 53
    Yes, I understand, I think... A bit of a language disconnect here I think Not that your English is bad, it's not bad at all, it's far far better than my ______(insert language here)...
    Those sequences of numbers above...What are they? Is that how you have it stored? Or is that how you want to display it...
    What is 25,55? Is it 25.55? Or is it 25, then 55, and so on (I realize in Europe and other parts of the world the comma ( , ) is used in much the same way that folks in the States use the decimal point)...
    Nov 2007
    They are in ACII code . I attach it .
    Is not impportant , is a separration sign between 25(integer) and 55(2 decimals)
  1. I2C Master/Slave 16F88/16F767 working code
  2. Cleaning up code
    Last Post: - 2nd December 2009, 07:14
  3. HARDWARE I2C SAMPLE CODE question
  4. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 00:22
  5. Sinus calculating !
    Last Post: - 28th November 2004, 23:56
