Write Onewire data toa I2C memory / read ASCI
Results 1 to 40 of 68
    Nov 2007
    If you read the PBP manual, you'll find commands in the LCD, I2Cxxxx, SERIN/SEROUT, HSERIN/HSEROUT, and various other sections that will show you have these various commands handle digits, decimals (which PBP does NOT natively handle), numeric characters, ASCII values, etc.etc.etc. DEC DIG HEX BIN, and all sorts of other good information in there...
    I know this , and I have used for LCD display , for serin/serout and work , but now I do not know how can use this commands for I2CXXXX. When I use one of this do not accept by MicroCode Studio .
    Quote Originally Posted by Eugeniu View Post
    You don't have to store them in eeprom in anyway out of the ordinary. If you can display it using those modifiers, then store the data as the raw data. Then recover it as raw data and display it using those modifiers again. You don't have to do anything special to store it.
    Nov 2007
    Can you give me a in context example ? Please !
    Thank you !
    Just exactly what you had...
    i2cwrite I2CDAT, I2CCLK, $A0, adr,[Byte_integer,Byte_decimal]
    Then read them back the same way and display them on the LCD seperately with a decimal point in between them.
    Nov 2007
    I do not use LCD , I use a 7 X 96 leds panel . With LCD is very simple ! Support all of these "DEC DIG HEX BIN,"
    Ahhh....ok....I see now...
    Well then...your answer is in post #2...
    Nov 2007
    I am sorry ! but I do not see in mind the solution for my problem .
    I say again : PLEASE ! SHOW ME IN CONTEXT EXAMPLE , in my programme.
  1. I2C Master/Slave 16F88/16F767 working code
  2. Cleaning up code
    Last Post: - 2nd December 2009, 07:14
  3. HARDWARE I2C SAMPLE CODE question
  4. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 00:22
  5. Sinus calculating !
    Last Post: - 28th November 2004, 23:56
