The best way to control a servo with a PIC
Results 1 to 40 of 42
    May 2007
    A single PIC18 @ 20MHz can control 24 servos with 256 steps:
    http://www.mikroe.com/forum/viewtopic.php?t=6192
    Jun 2007
    Mansfield, UK
    Im using a 16F (PIC16F87 to be more specific) @ 20MHz. Im sure it could handle 24 servos even with the way i did it. The problem is that the way i was doing it would have caused problems with the PWM for the LEDs. If PULSOUT allows the next few lines of code to run before it toggles back off then this should be really simple. I dont have anything to test on at the moment but when i get home ill give it a go
  1. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 08:40
  2. Help with Servo Control Please!
    By wireman22 in forum mel PIC BASIC Pro
    Last Post: - 7th June 2007, 18:15
  3. Servo control / UART / SPI help needed
    By Blackhawk in forum mel PIC BASIC
    Last Post: - 10th November 2006, 03:40
  4. How would i write this in pic basic pro (Servo controller)
    By Jhdgkss in forum mel PIC BASIC Pro
    Last Post: - 10th February 2006, 08:21
  5. Control RC servo via Parallax Servo Control
    Last Post: - 17th September 2005, 08:18
