Quick random thought...If you're used to using the 16F87/88, why not stick with them? They're only 4 pins more than the 'F688 discussed earlier...
Here's my addendum to the earlier post...
Say you've got a 'PWM counter' that runs from 0-2000 (actually a 20ms counter incrementing every 10 microseconds), you want desired_position '0' on the servo. Actual_Servo_Position = desired_position + 50 (0 in this case)...
if actual_servo_position < pwmcounter then servo-pin = 1, servo-pin will go high for .5ms (bare minimum for a servo probably), then be low for the rest of PWMcount until it resets itself.
or you want desired_position 2000 on the servo...
Actual_Servo_position = desired_position + 50 (2050 in this case)....same thing except servo-position will go high for 2.5ms (probably the absolute most), then be low for the rest of the count just like the other case...
You could easily put this in a tight little loop handling everything for you, reading the RCREG for any servo commands that come thru (or packets if you want to go that way) and still keep decent resolution on the servo itself.
