serial problem pic16F876(A)
Results 1 to 16 of 16
Threaded View
  1. #10
    o.k when you program the F876 did you change your DEVICE lines to DEVICE pic16f876 ???
    also the following define are not good for F876 if i refer to the p16f876.inc and p16f876a.inc files
    @ DEVICE pic16F876A, PWRT_OFF
    ' Power-On Timer
    @ DEVICE pic16F876A, BOD_ON
    ' Brown-Out Detect
    @ DEVICE pic16F876A, PROTECT_OFF
    so they probably refer programmer to something else. Must see p.16f876.inc files in your MPLAB\mchip_tools
    I saw in the migration sheet that theres some difference on programming method/timing. Also when programming did you select the good device (since F876 is not suppose to be the same am F876A)
    can you try slower baudrate ?
  1. Replies: 5
    Last Post: - 20th March 2006, 02:34
  2. Serial Communication Problem
    Last Post: - 23rd February 2006, 03:11
  3. Y A Serial problem
    By jswayze in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2004, 05:40
  4. Replies: 8
    Last Post: - 11th November 2004, 21:08
  5. 16F877, DS18S20 and Serial Comm Problem
    By YellowTang in forum mel PIC BASIC Pro
    Last Post: - 26th April 2004, 11:36
