USART to PC
Results 1 to 5 of 5
Thread: USART to PC
    Jan 2008
    Dublin, Ireland
    Default USART to PC
    Hi All
    I'm at the moment setting up A 16F88 to communicate with my pc's serial com port. My issue is with the many circuits I have seen and the way in which to wire up the MAX232 converter. Almost every circuit i look at has the max232 chip hooked up differently and the 4 capacitors seem to be connected with random polarity in all the diagrams...
    Anyway so far I've been unable to get a peep out of the terminal on the pc. Anyone know a circuit that definately works so I can be sure I have got this part right first.
    Cheers
    Tony
    skimask's Avatar
    skimask Guest
    Are you using a real, actual MAX232? Or one of the many derivatives out there?
    The datasheet for your particular MAX232 chip should show exactly where/how to place said capacitors...
    I thought you got out of the PicBasicPro business...
    http://www.picbasic.co.uk/forum/showthread.php?t=7808
    Hi Tony,
    Are you sure of which COM port you are using ? Which terminal program are you using ? Can you tell your terminal program to switch com ports?
    If not you may be able to change them in the computer's BIOS.
    Jan 2008
    Dublin, Ireland
    Hey Ski...No never, dont think i'll be leaving PBP any time soon although I have been cheating a little with Mikroe Basic!
    I think your referring to a copy of PBP I sold a while back I bought 2 at the time because the company I bought it off in Italy were selling them for around €100 each for the Pro version think it was a sale (without vat it was even less :-P).
    As for the chip, its a real MAX232CPE, allcircuits I was looking at used the MAX232 chip... anyway I was going to try again thisevening but I'm just too knackered, i'll give it a bash tomorrow and see how it all goes...
    All the Best
    Tony
    Jan 2008
    Dublin, Ireland
    Ok I lied about leaving it until tomorrow.... I just couldnt leave things alone! Anyway its all working now, I think it was just the polarity that was wrong.
    Tony
  1. PC to EUART on pic 16F688
    By docaberle in forum mel PIC BASIC Pro
    Last Post: - 25th October 2008, 07:33
  2. Sending menu to PC from PIC16F876A
    By joseph Degorio in forum Serial
    Last Post: - 12th November 2007, 08:03
  3. USART Problem , but don't know where, in pc? or in PIC?
    Last Post: - 15th July 2007, 09:12
  4. problem with USART
    By leemin in forum Serial
    Last Post: - 11th December 2006, 18:56
  5. Interrupt and Serial communication to PC.
    By obaskirt in forum mel PIC BASIC
    Last Post: - 17th June 2005, 21:01
