Gsm/Gps Tracker
Results 1 to 40 of 53
Thread: Gsm/Gps Tracker
    Quote Originally Posted by aratti View Post
    Did you powered the cable working with hyperterminal? If not you don't need to do it with max232.
    Al.
    When i use it with the pc hyperterminal there is no need for external power the com port it gives the power that i need it.
    Can i use in same code more the one Serout2/in2 on diferent ports to control phone and gps and others serial devices?
    May 2008
    Italy
    Yes you can. But when you service one device you don't see the others (If device A will send data while you are servicing device B, device A data will be lost"
    Al.
    Al.
    Ok thanks for the hellp e will later try ths max way that you told me.
    Xau
    Quote Originally Posted by camolas View Post
    I have not done phones, but the others many times.
    As long as the pin is set for digital SERIN/OUT/2 will work on any pin that is an I/O, You can have as many pins as you want taking turns doing serial.
    You can mix and match SERIN, SERIN2, and HSERIN.
    If you are slick, you can HSERIN on the hardware and SEROUT on another.
    Ok thanks for caring.
    Xau
    May 2008
    Italy
    Have you correctly placed the label "UM:" in your code?
    Al.
    Al.
    Hi ALL,
    Its was a small error its solved, I will post the new code using Serin2/out2.
    One more time thank you Sir. for hellping and caring.
    Xau
    Italy
    Lightbulb just my two cents
    Hi Camolas,
    about the signal coverage, what you think about to use:
    AT+CSQ
    it should tell you how good is the signal.
    In the modem I have it say that
    0 - 9 = very poor or not enough
    10 - 15 = good
    16 - 31 = very good
    May this help you.
    If you get your code even good for signal coverage, do you like to share it?
  1. solar tracker controller
    By CIRE in forum mel PIC BASIC Pro
    Last Post: - 15th November 2016, 15:16
  2. Help Idea Off infrared tracker
    By jetpr in forum General
    Last Post: - 11th September 2008, 08:22
  3. Replies: 1
    Last Post: - 27th July 2008, 06:14
