Not sure if this will help you now or not, but it might.
http://www.picbasic.co.uk/forum/showthread.php?t=544
Camolas, The array "numero" contain the string so:
For A0=8 to 19
arry[A0]=numero[A0-8]
next A0
Arry[20]=13
But you can put the value directly in arry[8] to arry[19] instead to put it in the array "numero"
Al.
Its final and full working code, any questions please asck.
@ Device HS_OSC
define OSC 20 ' Check the spelling of OSC, must be in capital letter
Include "modedefs.bas" ' Include serial modes
Define LCD_DREG PORTD
Define LCD_DBIT 4
Define LCD_RSREG PORTD
Define LCD_RSBIT 3
Define LCD_EREG PORTD
Define LCD_EBIT 2
Define LCD_COMMANDUS 2000 ' Command Delay (uS)
Define LCD_DATAUS 50 ' Data Delay (uS)
DEFINE LCD_LINES 2 'Number lines on LCD
DEFINE HSER_SPBRG 129 ' 9600 Baud @ 20MHz, 0.16%
LCDOut $FE, 1
Clear
sms var byte[10]
numero VAR BYTE[12]
Lat var byte[11]
Long var byte[11]
TrisB.7=0 ' LIGA GSM
TrisB.6=1 ' IGNIÇÃO
TrisB.5=1 ' SENSORES
TrisB.4=0 ' FEXA PORTAS
TrisB.3=0 ' PISCAS
TrisB.2=0 ' IMOBLIZA
TrisB.1=0 ' ?????????????
TrisB.0=0 ' LED OK VERDE
TrisC.4=1 ' RX BT
TrisC.5=0 ' TX BT
TrisC.6=0 ' TX GSM
TrisC.7=1 ' RX GSM
TrisD.1=1 ' RX GPS
Low PortB.1
Low PortB.2
Low PortB.3
Inicio:
Low PortB.0
Pause 500
High PortB.0
Pause 500
Low PortB.0
Pause 500
High PortB.0 'pisca 3 vezez e desliga
Pause 500
Low PortB.0
Pause 500
High PortB.0
Pause 500
Low PortB.0
Pause 2000
UM:
Low PortB.1
HSEROUT["at",13,10]
HSERIN 10000,UM,[WAIT("OK")]
LCDOut $FE, 1,"ON"
HIGH PortB.0
DOIS:
serin2 portD.1, 188, [WAIT("$GPRMC,"),skip 13, STR LAT\11,skip 1, STR Long\12]
High PortB.1
HSEROUT["AT+CMGF=1",13,10]' Modo Texto
LCDOut $FE, 1,"ok"
HSEROUT["AT+CMGR=1",13,10] ' Ler sms
HSERIN 5000,UM,[WAIT("REC UNREAD"),skip 3, STR numero\13,skip 27,STR sms\10]
IF sms[0]="S" and sms[1]="t" and sms[2]="o" and sms[3]="p" Then
goto Tranca
Endif
IF sms[0]="C" and sms[1]="e" and sms[2]="l" and sms[3]="i" and sms[4]="a" Then
goto Destranca
Endif
IF sms[0]="P" and sms[1]="o" and sms[2]="s" Then
goto PO
Endif
Goto APAGA
Tranca:
High PortB.3 'Piscas
Pause 500
High PortB.2 ' Imobliza
Goto PO
Destranca:
Low PortB.3 'Piscas
Low PortB.2 ' Imobliza
Goto APAGA
Liga: ' LIGA GSM
High PortB.7
Pause 20000
Goto UM
PO: ' Enia localizacao
HSEROUT["AT+CMGS=",34,STR numero, 34,13]
hserin 10000,PO,[WAIT(">")]
Lo:
HSEROUT["LAT: ",LAT (10),"-", LAT, lat (1),"'",lat (2),Lat(3),".",lat (5),lat(6),lat (7),lat(8),$fe,$c0,"LON: ", Long(11),"-", Long (1),long (2),"'",Long (3),long (4),".",Long (6),long (7),long(8),long (9),13,10]
hserin 10000,lo,[WAIT(">")]
Li:
HSEROUT[26]
hserin 10000,li,[WAIT("OK")]
APAGA:
HSerout ["AT+CMGD=1",13,10]' apaga sms 1
hserin 10000,APAGA,[WAIT("OK")]
HSerout ["AT+CMGD=2",13,10]
Pause 5000
goto Inicio
Thanks for all the help that you gave me.
Xau.
Your code must hang if there is no enough deposit on the sim card, alternativelay u can see gsm network connectivity available for make more reliable the sms dispachting, i don't know how that cell phone works but if it has log for sms in areas without gsm coverage and the pic still in the Lo loop, once you are back on GSM coverage, simply alll your deposit can be wasted in several hundred SAME message !!
but . . . is just my point of view...![]()
Thanks for the inputs, for the deposit there is no problem because in my code i delet the "REC UNREAD" sms
"APAGA:
Pause 5000"
The gsm coverage is very good point that you have made it need to be changed in a futer update.
I have been in a wardware problem now this works very good in a QL200-A4 board but in my home made pcb not (some times works some not..) the pic cant get the phone Tx (i see it in hyperterminal that phone gets the pic Tx e reply but pic cant get it) i have put a 10K pulldown and up in phones Tx but no sucess.Need hellp on that if you mates can hellp me thanks.
Xau.
Camola, remove the resistors from the serial line and use a Max232.
Al.
Hi Al,
Ive removed the res and wired like this but no sucess
<a href="http://imageshack.us"><img src="http://img509.imageshack.us/img509/3451/maxpt7.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a><br/><a href="http://g.imageshack.us/img509/maxpt7.jpg/1/"><img src="http://img509.imageshack.us/img509/maxpt7.jpg/1/w677.png" border="0"></a>
Xau
