Gsm/Gps Tracker
Results 1 to 40 of 53
Thread: Gsm/Gps Tracker
Threaded View
  1. #5
    Here is my full and working code for a gps/alarme/gsm.
    @ Device HS_OSC
    define OSC 20
    Include "modedefs.bas" ' Include serial modes
    Clear
    sms var byte[10]
    numero VAR BYTE[12]
    Lat var byte[11]
    Long var byte[11]
    TrisB.7=0 ' LIGA GSM
    TrisB.6=1 ' IGNIÇÃO
    TrisB.5=1 ' SENSORES
    TrisB.4=0 ' FEXA PORTAS
    TrisB.3=0 ' PISCAS
    TrisB.2=0 ' IMOBLIZA
    TrisB.1=0 ' ?????????????
    TrisB.0=0 ' LED OK VERDE
    TrisC.4=1 ' RX BT
    TrisC.5=0 ' TX BT
    TrisC.6=0 ' TX GSM
    TrisC.7=1 ' RX GSM
    TrisD.1=1 ' RX GPS
    Low PortB.1
    Low PortB.2
    Low PortB.3
    Inicio:
    Low PortB.0
    Pause 500
    High PortB.0
    Pause 500
    Low PortB.0
    Pause 500
    High PortB.0
    Pause 500
    Low PortB.0
    Pause 500
    High PortB.0
    Pause 500
    Low PortB.0
    Pause 2000
    UM:
    Low PortB.1
    HSEROUT["at",13,10]
    HSERIN 10000,UM,[WAIT("OK")]
    LCDOut $FE, 1,"ON"
    HIGH PortB.0
    DOIS:
    serin2 portD.1, 188, [WAIT("$GPRMC,"),skip 13, STR LAT\11,skip 1, STR Long\12]
    High PortB.1
    HSEROUT["AT+CMGF=1",13,10]' Modo Texto
    HSEROUT["AT+CMGR=1",13,10] ' Ler sms
    HSERIN 5000,UM,[WAIT("REC UNREAD"),skip 3, STR numero\13,skip 27,STR sms\10]
    IF sms[0]="S" and sms[1]="t" and sms[2]="o" and sms[3]="p" Then
    goto Tranca
    Endif
    IF sms[0]="C" and sms[1]="e" and sms[2]="l" and sms[3]="i" and sms[4]="a" Then
    goto Destranca
    Endif
    IF sms[0]="P" and sms[1]="o" and sms[2]="s" Then
    goto PO
    Endif
    Goto APAGA
    Tranca:
    High PortB.3 'Piscas
    Pause 500
    High PortB.2 ' Imobliza
    Goto PO
    Destranca:
    Low PortB.3 'Piscas
    Low PortB.2 ' Imobliza
    Goto APAGA
    Liga: ' LIGA GSM
    High PortB.7
    Pause 20000
    Goto UM
    PO: ' Envia localizacao
    HSEROUT["AT+CMGS=",34,"+351xxxx32xxx", 34,13] ' Phone number to get the gps sms data
    hserin 10000,PO,[WAIT(">")]
    HSEROUT["LAT: ",LAT (10),"-", LAT, lat (1),"'",lat (2),Lat(3),".",lat (5),lat(6),lat (7),lat(8),$fe,$c0,"LON: ", Long(11),"-", Long (1),long (2),"'",Long (3),long (4),".",Long (6),long (7),long(8),long (9),13,10]
    HSEROUT[26]
    APAGA:
    HSerout ["AT+CMGD=1",13,10]' apaga sms 1
    hserin 10000,APAGA,[WAIT("OK")]
    HSerout ["AT+CMGD=2",13,10]
    Pause 5000
    goto Inicio
    I get sender number (numero VAR BYTE[12]) but cant use it in the HSEROUT["AT+CMGS=",34,"+351xxxx32xxx", 34,13] i try HSEROUT["AT+CMGS=",34,"Str numero", 34,13] but no sucess can the masters give me some hellp?
    Xau
  1. solar tracker controller
    By CIRE in forum mel PIC BASIC Pro
    Last Post: - 15th November 2016, 16:16
  2. Help Idea Off infrared tracker
    By jetpr in forum General
    Last Post: - 11th September 2008, 09:22
  3. Replies: 1
    Last Post: - 27th July 2008, 07:14
