Exploring Pic16F628a...
Results 1 to 12 of 12
    Hserin is always better than serin, works in the background while other code executes as it is hardware based vs bitbang software. I think you are going to need to use a crystal vs intosc because of timing issues especially if you want to use high speed communications, the example I gave you is really too fast for internal OSC, should probably slow it down to something like 300. If you want to use HSERIN you will have to use the appropriate ports, so yes RB1 (RX) as input, there is some code you have to add to use HSERIN too, lots of example code in this forum.
    Oct 2008
    Thanks for the help Joe appreciate it very much.
    mbox
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 22:14
  2. Do I need a pause?
    By tazntex in forum Serial
    Last Post: - 29th August 2008, 04:32
  3. Help Pic16f628a
    By gadelhas in forum mel PIC BASIC Pro
    Last Post: - 26th August 2008, 23:22
  4. Changing bits in a byte for multiple output
    Last Post: - 11th August 2008, 19:10
  5. Replies: 8
    Last Post: - 22nd July 2008, 20:31
