Exploring Pic16F628a...
Results 1 to 12 of 12
Threaded View
  1. #8
    Oct 2008
    Default re:
    Good morning Joe,
    I compiled your updated code with no errors, and it says 183 words used....Running leds from PortB.0-PortB.2. until myvar reached 0 value (very nice).
    On the main label, As you mentioned and as I understand it, if any high value reads on PortA.0-PortA.2 a numeric value on variable Led1 will be assigned and test if the conditions are true to turn on(high) PortB.0 - PortB.2.
    thanks,
    mbox
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  2. Do I need a pause?
    By tazntex in forum Serial
    Last Post: - 29th August 2008, 05:32
  3. Help Pic16f628a
    By gadelhas in forum mel PIC BASIC Pro
    Last Post: - 27th August 2008, 00:22
  4. Changing bits in a byte for multiple output
    Last Post: - 11th August 2008, 20:10
  5. Replies: 8
    Last Post: - 22nd July 2008, 21:31
