Am I stupid? Goto does not GOTO??? Where's the bug??
Results 1 to 16 of 16
    Quote Originally Posted by xnihilo View Post
    Right, but I need them to have bypass when multiple IF statements are used so not all IF are checked.
    Select Case will exit as soon as true.
    May 2007
    Select case only works with a single variable. The OP is testing several different variables.
    OK, so he is using PortB as inputs, so assuming only 1 leg is triggered at a time then PORTB.0 = 1 then PORTB = 1, PORTB.1 = 1 then PORTB = 2, PORTB.2 = 1 then PORTB = 4 . . . a lookup table could be used to assign whatever point value he wants.
    Index = PortB
    Lookup2 Index,[100,200,300,400,500], pin
    xnihilo's Avatar
    xnihilo Guest
    Index = PortB
    PORTA, actually.
    And more than one pin at a time may be triggered.
    There is no such thing as SWITCH (C language)?
    Ok Port A, b whichever. A port Typically has 8 I/O lines and can be read like any register, and can hold the value 0 to 255 counting in binary. In "C" they call it SWITCH CASE in PBP it is SELECT CASE.
    xnihilo's Avatar
    xnihilo Guest
    Thank you for this info.
  1. Making a menu
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 12th November 2008, 20:54
  2. Replies: 14
    Last Post: - 26th September 2007, 06:41
  3. Problems with RC2 and RC3
    Last Post: - 29th May 2006, 18:19
  4. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
  5. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 21:10
