I have this code in an int handler
I was expecting to have a display of "1pin = " and the pin nr but guess what I guess:Code:'check what pin triggered the int 'we have the time of the header pulse to manage that work if (head == 0) THEN pin = 0 'set the number of the pin for the score managment (update_scores) GOTO got_pin 'bypass ENDIF if (front == 0) THEN pin = 1 GOTO got_pin 'bypass ENDIF if (back == 0) THEN pin = 2 GOTO got_pin 'bypass ENDIF if (larm == 0) THEN pin = 3 GOTO got_pin 'bypass ENDIF if (rarm == 0) THEN pin = 4 GOTO got_pin 'bypass ENDIF 'if (porta.5 == 1) THEN ' pin = 5 ' GOTO got_pin 'bypass 'ENDIF 'ELSE: LCDOUT $fe,1,"0pin = ",#pin PAUSE 2000 pin = 111 got_pin: 'TEST block LCDOUT $fe,1,"1pin = ",#pin GOTO finish
"0pin = " and the pin number.
It completely ignores my GOTO got_pin.
How can it be??
I've spen many hours working on my program so maybe the error is so obvious I don't see it...
Could someone open my eyes please?
