Nested IF THEN Statements
Results 1 to 5 of 5
    cjsanders's Avatar
    cjsanders Guest
    Default Nested IF THEN Statements
    What is the maximum # of Nested IF THEN's you can have with a 16F877 MCU?
    Does the Compiler warn you if you exceed this number?
    as i expect you can have as many as you want or program memory is able to contain them.
    I don't see any reason why it should have a maximum. BUT maybe i'm wrong.
    Sometime SELECT CASE is a good way to reduce IF THEN statements.
    Dec 2003
    Wichita KS
    I seemed to remember a Maximum of 4 nested.
    I have been trying to call up the manual to doublecheck my
    answer, but the site doesn't seem to be working.
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    That's subroutines with a 4 max. IF... THEN's do not use the stack and therefore have no restriction. The compiler will warn you if you run out of program codespace.
    Dec 2003
    Wichita KS
    Melanie>>That's subroutines with a 4 max. IF... THEN's do not use the stack and therefore have no restriction<<
    Thanks a MILLION!... I knew I remembered something like a max of 4 on something...Since I may never met that max, I just blow it off.
    Dwayne
    Ability to Fly:
  1. Nested For Next Loop Demo
    By Archangel in forum Code Examples
    Last Post: - 8th June 2009, 08:57
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  3. Multiple IF-THEN statements
    By DavidK in forum mel PIC BASIC Pro
    Last Post: - 20th June 2007, 18:28
  4. Proton Commands & statements
    By Lotondo in forum mel PIC BASIC Pro
    Last Post: - 6th November 2006, 23:37
  5. If - then statements
    Last Post: - 18th May 2006, 22:57
