how can i stop the pic from sending a PWM???
Results 1 to 6 of 6
    Aug 2008
    Default how can i stop the pic from sending a PWM???
    hi all.my pic16f877a did generate the 125kHz with 50% (get from this forum,thanx) but i don't know how to turn it off.what i mean is if i push the button 1 pic will generate the pwm & when i push the button 2 pic will stop from generate it (on/off the PWM).
    here is my coding:
    define osc 8
    TRISC = 0 'PORTC all outputs
    TRISB.5 = 1
    TRISB.4 = 1
    push1 var portb.5
    push2 var portb.4
    if push1 = 0 then inject
    if push2 = 0 then notinject
    inject:
    PR2 = 15 'Load Period Register
    CCPR1L = 8 'Set 50% duty cycle
    CCP1CON = %1100 'PWM mode
    T2CON.2 = 1 'Start TIMER2
    goto inject
    notinject:
    goto notinject
    i don't know what to fill in the "??????"....i have try to set the TMR2=0, CCP1CON=0 & T2CON.2=0 but it did not work...help me please....
    This should work.
        DEFINE OSC 8
        TRISC.2 = 1  ' CCP1 pin stays input intil PWM on
        TRISB.5 = 1  ' button input (external pull-up with switch to ground)
        Push1 var PORTB.5
      TRISC.2=Push1 ' if RB5=0 CCP1 pin is an output, PWM=on
      GOTO Main     ' if RB5=1 CCP1 pin is an input, PWM=off
    The PWM module is still operationg so you shouldn't have any glitches in the signal, and
    you only need one button to control it.
    When the CCP1 pin is switched to an input, the PWM signal is disconnected. When it's
    flipped to an output it's back on.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Aug 2008
    wow.simple solution.haha.thanx a lot bruce.but are your coding mean i need to hold the push button to PWM on & release the button to PWM off...or push the button once to PWM on & push once again to PWM off????
    Quote Originally Posted by texas5 View Post
    Read the code! Do you see anything in that code saving the state of the button to remember for the next time the loop checks the buttons state?
    The bit in the TRIS register follows the state of the push button...simple as that...just like it's written...
    Yep. Like Ski said, that's how it works.
    Here's another flavor.
      IF Push1=0 THEN
         GOSUB ChkState
      GOTO Main
    ChkState:
      WHILE Push1=0       ' wait for button release
      WEND
      TRISC.2=TRISC.2 ^ 1 ' toggle TRISC.2 on button release
    Endless simple possibilities.
    -Bruce
    tech at rentron.com
    Aug 2008
    thanx guys.it work....
  1. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  2. Sending Commands from Visual Basic about IR to Pic
    By tne_de in forum mel PIC BASIC Pro
    Last Post: - 29th April 2009, 07:09
  3. Replies: 9
    Last Post: - 8th October 2008, 12:15
  4. Sending data from 1 pic to other pic
    By PoTeToJB in forum mel PIC BASIC Pro
    Last Post: - 12th September 2007, 01:51
  5. VB sending serial data to PIC
    By Tissy in forum Serial
    Last Post: - 8th March 2006, 19:31
