Comparing different types of variables
Results 1 to 10 of 10
    Quote Originally Posted by The Master View Post
    Hi, Im trying to compare a WORD with a BYTE. Should that work in PBP? Im using "=>". When the values are actually compared the WORD value is definately less than 256. When i compare 2 BYTE values it works fine but if i change one to a WORD then it stops working.
    Im not sure if the problem is with the comparison but it looks most likely. Does anyone know anything about it?
    if word.lowbyte => bytevalue then xxxxxx
    or
    if word.highbyte => bytevalue then xxxxxx
    Don't know why it's not working for you in the first place. It should. Works for me anyways...
    Jun 2007
    Mansfield, UK
    Im sure its worked for me in the past too. I had already tried word.byte0/1 but i tried high/lowbyte too and still no luck. The problem i have is that the byte always seems to be less than the word. I just checked it with a status light on and aparently the byte is always 0 because no serial data arrives. The word doesnt have anything to do with serial so ive no idea whats happening there :S
    Ill see if i can figure it out. I know its not the compare code now
    Jun 2007
    Mansfield, UK
    Ive found where the problem is. I commented all the relative code out then turned it back on 1 line at a time until it broke again.
    At the top i have this code
    cServoOffTime con 255
    pServo1 var PORTA.3
    vServo1Pos var WORD
    In the interrupt handler for TMR0 i have this code
                    if vservo1pos>=cservoofftime then
                        pServo1=1
                        vservo1pos=0
    If i comment out the if statement (not the code in it, just if-then and endif) or i change vServo1Pos to a byte then it works fine. As it is above it stops any serial data from being received. I dont get how that could possibly affect it
    Don't know if it'll make ANY difference at all but...
                    if vservo1pos  =>  cservoofftime then
                        pServo1=1
                        vservo1pos=0
    Jun 2007
    Mansfield, UK
    Unfortunately not, I already tried that because some languages like PHP dont like it if you put them in the wrong order. PBP doesnt seem to mind though.
    Ive been testing a different line of code that does almost the same thing
    if vservo1pos=>vservo1+12 then
    When i use that code i can send serial data fine for about 5 seconds then it stops. It looks similar to a problem i had the other day but that was because i wasnt resetting a variable back to 0 when i should have. This code shouldnt affect that variable at all though. The PIC doesnt stop running because it still generates the pulse
    If vservo1 ends up being greater than 65,524, then vservo1 + 12 = 65536, which in a WORD variable ends up equalling ZERO...
    Jun 2007
    Mansfield, UK
    vServo1 is a byte and cant go above 255.
    I will try declaring cServoOffTime as a variable instead. I think something similar to this was the reason for my thread about the datatypes of constants
    What happens if you do this:
    cServoOffTime var WORD
    cServoOffTime = 255
    pServo1 var PORTA.3
    vServo1Pos var WORD
                        pServo1=1
                        vservo1pos=0
  1. Max Variables
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 19th January 2008, 04:05
  2. Changing declared variables names on the fly
    Last Post: - 16th December 2006, 06:34
  3. Variables not appearing in Watch Window MPLabv7.3
    Last Post: - 16th June 2006, 14:36
  4. edit names of variables
    By mischl in forum mel PIC BASIC Pro
    Last Post: - 13th January 2005, 21:00
  5. Problems with variables
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 15th December 2004, 18:37
