Xor?
Results 1 to 9 of 9
Thread: Xor?
    skimask's Avatar
    skimask Guest
    Look under Bitwise NOT in the manual
    Byte = ~ Byte
    EDIT: I've got no idea why this post ended up ahead of jderson's post below!!!
    Bombay, India
    You're a prophet
    Default Xor?
    I'm trying to invert all bits of a byte variable, no matter what the value is. Do I need to make a lookup table for all the numbers?
    Thank you, Skimask. It works now, but I don't see where ~ is in the manual.
    Dec 2005
    Look at the timestamps.
    Dec 2005
    Quote Originally Posted by jderson View Post
    There's a table listing all operators near the beginning of the manual - I don't have the manual handy or I'd give the page number.
    I found it on page 32, thank you.
    skimask's Avatar
    skimask Guest
    Well, that's what I mean. I was posting AFTER he already posted (obviously)...
    Something was/is an hour off...wasn't my PC...
    Omaha, Nebraska USA
    I may be out of practice with binary operations. Couldn't you just use (255 - VARIABLE)?
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
  1. A logic gate chip with 1 ea XOR and 2 ea AND gates?
    Last Post: - 5th August 2009, 05:29
  2. XOR result different with PC application
    Last Post: - 26th January 2009, 04:56
  3. Xor Sum
    By Sphere in forum General
    Last Post: - 7th December 2006, 07:52
  4. Exclusive OR - XOR
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 14th September 2006, 09:44
  5. Checksum / CRC8 / CRC16
    By treitmey in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2003, 14:40
