counter
Results 1 to 2 of 2
Thread: counter
    Oct 2008
    Default counter
    can someone help me with a counter for picbasic who count the puls of a 40 Mhz model sender?
    I need it for the savetyboard for my modelsubmarine.
    My pic needs to know if there are coming signal out of the receiver.
    Oct 2003
    holland
    To detect if the 40MHz is there with a normal pic is not possible.
    What you can do is next:
    Build a detector for the LF signal the transmitter is sending.
    A coil and a capactor in parrallel tuned on the right frequency a diode a resistor and a capacitor will do.
    This detected LF signal is than after amplified or via a comperator fed to the pic.
    Then you can compare in the programm of the pic if the right code was sent.
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Counter not counting !!!
    Last Post: - 20th February 2009, 23:15
  3. Replies: 42
    Last Post: - 14th January 2008, 12:38
  4. 20 Digit Virtual LED Counter
    Last Post: - 19th November 2007, 06:02
  5. Microcontroller with 2 way paging application problem
