PTO Generator
Results 1 to 8 of 8
Thread: PTO Generator
    Sep 2010
    Las Vegas, NV
    Default Re: gen hook-up
    Niagara Generator has a home page and appears to have a customer service number. Sears looks like it sells parts for some Niagara/Generac generators. Contacting either may yield a manual or operating instructions. That might get you rotational position without having to measure phases. I'd bet there are some markings on the shaft/housing to ensure correct phasing. I also wonder if the xformers tie may be corroded. That would be easy to check by measuring resistance between neutrals.
    If you go the transformer route to compare phases I'd caution you to be very careful. I don't think there will be a GFI and if so it won't quit until those 60 amp breakers trip. It could tingle a bit. I don't see any way to do it differently though if there are no markings to ensure correct phasing.
    so, if there are 2 independent windings which can be hooked series or parallel, test phasing as follows,
    if you are sure there are no other connections on output legs, you can join 1 connection and meter the legs to determine the phasing and output voltages for different hookups. careful
  1. 2 Beam Optical Pulse Generator
    By WOZZY-2010 in forum Schematics
    Last Post: - 6th April 2010, 05:03
  2. 4 to 20 mA generator help
    By Snap in forum mel PIC BASIC Pro
    Last Post: - 30th October 2008, 13:55
  3. Custom Character Generator
    By Darrel Taylor in forum FAQ - Frequently Asked Questions
    Last Post: - 27th October 2008, 19:03
  4. Frequency Generator
    By ExYu in forum Off Topic
    Last Post: - 22nd January 2008, 19:25
  5. Working with the random number generator
    By kwelna in forum mel PIC BASIC
    Last Post: - 16th January 2007, 18:50
