Pic16f886
Results 1 to 2 of 2
Thread: Pic16f886
    Oct 2008
    Default Pic16f886
    I've had difficulty using an external osc. with the '886. I could find no PICBasic configuration for it in the on-manual,nor any sample programs, as this chip is fairly new. I finally used: "@ DEVICE HS_OSC" (before defining OSC speed) That works, but is machine language. Anyone using the '886 or 887 who has found a PICBasic line that will tell the PIC to use an external Osc.? I also am having some problems using the analog inputs. They apparently are not used the same way as the old '876. I may find the answer later, as I have not spend much time worrying about the inputs as yet. Anyway, the '886 is not directly replaceable with the '876, and they suggest it is. Any thoughts anyone?
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by Larry View Post
    Who are THEY? Because THEY are only half right. The '886 is relatively PIN COMPATIBLE with the '876(a), and is also almost 100% compatible at the binary level, but it is a bit of a different animal...newer...better...more options...
    Read thru that, those are some of your options for setting the config fuses. There are no 'DIRECT' PicBasicPro statements to set those config fuses. You can only get to that sort of thing indirectly.
  1. Config problem PIC16F886
    By Bosse in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2014, 06:24
  2. PIC16F886 Register Settings
    By aherrera in forum mel PIC BASIC Pro
    Last Post: - 29th July 2009, 17:52
  3. Replies: 3
    Last Post: - 16th October 2007, 00:01
  4. PIC16F886 programming problems
    By mmargolis in forum General
    Last Post: - 3rd August 2007, 01:19
  5. Setting Fuses using Microcode Studio Plus
    By NO2K in forum mel PIC BASIC Pro
    Last Post: - 18th May 2007, 23:14
