as i see this code... look at your IF THEN statements
time:
                if time_pick < 13308 then time1
	if time_pick < 26615 then time2
	if time_pick < 39722 then time3
	if time_pick < 52829 then time4
	time_pick = 1500 : return
time1:
	time_pick = 800 : return
RETURN statement are use with GOSUB. In this case theres no gosubs, so your program don't know where to return. simply modify as
                if time_pick < 13308 then GOSUB time1
	if time_pick < 26615 then GOSUB time2
	if time_pick < 39722 then GOSUB time3
	if time_pick < 52829 then GOSUB time4
this is suppose to fix your problem
can also do
if time_pick<13308 then
time_pick=800
maybe less jumping between here, there, somewhere will be more easy to debug.
