Counting bits
Results 1 to 4 of 4
Thread: Counting bits
    Omaha, Nebraska USA
    Default Counting bits
    Does anyone know a quick and easy (or sneaky) way to count bits?
    I want to look at either the top or bottom 4 bits of a word and determine whether an odd or even number of bits are high (or low; doesn't matter).
    Right now, I'm using LOOKDOWN and it works just fine; but I keep thinking there's a more elegant way to do it.
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    Hi Russ,
    Not particularly "Sneaky" ... but it's "Quick".
    Counter  VAR BYTE BANK0
    ODD      VAR Counter.0
    TestWord VAR WORD BANK0
        clrf   _Counter
        btfsc  _TestWord,0
        incf   _Counter, F
        btfsc  _TestWord,1
        incf   _Counter, F
        btfsc  _TestWord,2
        incf   _Counter, F
        btfsc  _TestWord,3
        incf   _Counter, F
    If ODD THEN
      ; ODD number of bits in the TestWord<3:0>
    Last edited by Darrel Taylor; - 10th October 2008 at 08:57. Reason: Changed Count to Counter
    Hi, Russ
    first, shift right your word 12 times if > 4095 ...
    mask the result to keep the 4 lower bits,
    then 6 possibilities remain for an even count of the bits ...
    ( call the result "ABCD" ... if even, ABCD = Ch,Ah,9h,6h,5h or 3h )
    A SELECT CASE will do it.
    mask your word to keep the 4 lower bits
    Then 6 possibilities ...
    The SELECT CASE ...
    it's one way ...in PbP !!! ( lol )
    or use "NCD" function in a loop ... which looks furiously to what Darrel Wrote !!!
    Omaha, Nebraska USA
    Thanks to both of you.
    I'm emulating a 16-bit twisted ring counter--actually a very twisted counter. If an even number of bits in the top four are high, the whole works is shifted left one place and the lowest bit is set to 1; if an odd number of bits are high, again a one-place shift left, but the default 0 shifted in is retained.
    Just now, the target device is a 16F87xA.
    Russ
    Last Post: - 14th June 2016, 07:55
  2. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  3. PIC's ports individual bits manipulation - how to?
    Last Post: - 27th February 2007, 22:34
  4. Need clever way to convert 10 bits to 8 bits
    By MikeTamu in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2005, 15:13
  5. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 14:31
