Total Motor Currents
Results 1 to 30 of 30
    In large industrial installations, you are supposed to switch-in banks of Capacitors in the plant room to keep the Power Factor within limits set by the electric company if it is distorted by large amounts of (inductive load) machinery. If you don't, you are liable to fines and/or surcharges by the electric company on your energy usage. If you know how, and throw your current and voltage sufficiently out of phase, you can actually run your entire house for 'free'. If you are really clever, by the correct phase difference, you can not only slow-down your electricity meter, you can stop it completely - and with some older mechanical types have the meter go BACKWARDS, so the electric company ends up paying you for the electricity you use. You may find the 'small print' on your electricity supply contract threatens you with dire consequences if you extend your experiments in self-sufficiency in this direction.
    What kind of cap's are we talking about here? Are we talking about those huge oil filled jobs (not the transformers, I know what those are), switched in and out with a huge set of contactors at will by a 'Power Factor Controller' or something to that effect?
    Hi, Darrel
    When adding the current for the 2 motors, you should calculate a VECTORIAL addition ...
    but the sum modulus of two vectors is not compulsory equal to the sum of the modulii ... generally, It's lower ...
    Your results mean current for both motors have a different de-phasing ( ? ) ,called Cos Phi in Europe, from voltage.
    Feb 2005
    Kolkata-India
    Default Are you measuring the voltage anyway
    Hi, Darrel
    While that explains the phenomena, you should be busy working up the remedy.
    Possibly you would need to sample the voltage as well and find the phase difference between the current and voltage to calculate active/reactive/average power. While zero-cross detection can be used on the current and voltage sampled approach can also work.
    Consult AN939 from the mchip website. And here is something that may interest you http://www.circuit-magic.com/acpower.htm
    Sougata
    Dec 2005
    Darrel, you need to read up on Power Factor. It is an issue with all non-linear (i.e. reactive) loads, even very small loads. Voltage and current are out of phase so measurements can be misleading. Wikipedia is as good a place to start as any - it explains the fundamentals.You wrote that the PIC measures currents. How are you doing this?
    Yes, absolutely correct.
    Don't you all recall having to remember the word CIVIL at school? (referring to the fact that in a Capacitive C load, the current I leads the voltage V. In an inductive L load the voltage V leads the current I). Measure time difference between both (zero cross is easiest), simple math determines the rest.
    I just saw that 'CIVIL' acronym at Wikipedia...never seen that one before, only 'ELI the ICE man'.
    I've never had any sort of 'formal' electronic training, unless you count my USAF tech school (didn't learn anything there) or that 7 week Micro-Mini-Circuit-Card-Repair school I took about 18 months ago (learned almost too much there! and lost of a lot of bad habits!).
    The Cap Banks - I just never put 2 and 2 together as far as those banks go. I guess I always thought they were transformer banks of some sort...
    "CIVIL"?
    Never heard of it.
    After this thread ... that was probably obvious.
    "CIVIL"?
    Never heard of it.
    A little more time down in K-town, and we might've heard of it eventually eh?
  1. Controlsystem for compact sporting (clay shooting)
    By Fredrick in forum mel PIC BASIC Pro
    Last Post: - 30th July 2009, 17:48
  2. Total Newbie...
    By Frozen001 in forum mel PIC BASIC Pro
    Last Post: - 9th August 2008, 08:28
  3. Replies: 1
    Last Post: - 18th April 2006, 20:11
  4. Realtime video
    By RUBiksCUbe in forum mel PIC BASIC Pro
    Last Post: - 28th November 2005, 08:46
