18f4620
Results 1 to 9 of 9
Thread: 18f4620
    Moldava's Avatar
    Moldava Guest
    Default 18f4620
    hello,is the 18f4620 suported by pbp?
    thanks!
    You should first of all check on the manufacturers website for the latest release info... after all they're the folks that make it...
    http://www.melabs.com/products/pbp.htm
    and when you look down the list at the bottom of the page you then discover the words...
    "PicBasic Pro Compiler now supports ALL Microchip PICmicro MCUs!"
    And if you still don't believe it, look your favourite PIC up in the list provided.
    Moldava's Avatar
    Moldava Guest
    Thanks...
    my error was that microcode does not support it,but in the pbp folder i saw the definitions for this one...
    Moldava's Avatar
    Moldava Guest
    Smile
    ...but i supose,and will try,to add it manually to the microcode definition list...
    of course it will work. edit pic.ini file in the MCS folder, add your PIC and that's it that's all!!!
    Moldava's Avatar
    Moldava Guest
    Thumbs up
    Thanks again!!
    Beavis's Avatar
    Beavis Guest
    edited due to stupidity...........
    Jan 2010
    Default did that
    and the programm did not run properly, its supposed to be in the main right before TRIS initialisation, isn't it? and another thin gdoes anyone here did a wireless connection using 4620 with rfm or a similar device?
    Quote Originally Posted by bluestar84 View Post
    Welcome to the forum,
    Try starting a new thread with the problem you are having.
    Post the troubled code and anything else that has to do with your project. Makes it a lot easier to help you.
    Look at the threads linked here.
    http://www.picbasic.co.uk/forum/showthread.php?t=11116
    Many of the problems one has are answered there.
    Good luck!!!
  1. Migration 18F452 --> 18F4620
    By NavMicroSystems in forum General
    Last Post: - 27th January 2010, 12:58
  2. 18F4620 and SHT11 problems
    By wjsmarine in forum mel PIC BASIC Pro
    Last Post: - 27th June 2009, 11:26
  3. 16F877A to 18F4620 error
    By IMADK in forum mel PIC BASIC Pro
    Last Post: - 8th November 2007, 01:39
  4. 18F4620 refuses to be re-programmed
    By MaxG in forum Off Topic
    Last Post: - 4th December 2006, 09:16
  5. 16F877a to 18f4620 compatible?
    By modifyit in forum mel PIC BASIC Pro
    Last Post: - 6th February 2006, 01:24
