Access pin using index
Results 1 to 13 of 13
    xnihilo's Avatar
    xnihilo Guest
    Quote Originally Posted by Sharky View Post
    I am not really sure that I understand your question.
    I assume that you have an change on PORTA interrupt and that you want to know which of PORTA pins that triggered your interrupt.
    Maybe you could as the first thing in your interrupt handler read the lower 5 bits of PORTA to see there status.
    If I remember it right (don't have my manual here at work)
    You can isolate the lower 5 bits and put them into a variable
    youvar = PORTA & $1f    ' put lower 5 bits of PORTA into youvar
    Then if PORTA.3 is low and the others are high you will get the value 23 in youvar
    Hope I remember it right
    No, I know what pin triggered the int. I jut can write a routine that will read the incoming data on the specific pin as I don't know at the time I write he routine what pin it will be so I have to use an index but there is no way I can make it work.
    sinoteq's Avatar
    sinoteq Guest
    Default Using index and pins
    Hi
    Indexing pins is not a totally safe thing to do with PBP. This is a "Extra feature" and works really great with some commands and not at all with others. I have had some really strange results using indexed pins and Pulsin. It would not be a big surprise if While was a no-no.
    One other thing, please forgive me if I am wrong, are you sure you are using Interupt? When I look at your code. Unless it is in the interupt handler I would say you are polling the pin to get the status and generate a "software interupt". IF this is the case there are more efficient ways to do that is much faster and will save a ton of codespace.
    if (porta.0 == 0) THEN
    pin = 0 'set the number of the pin for the score managment (update_scores)
    GOTO got_pin 'bypass
    sheepdog's Avatar
    sheepdog Guest
    Will it work via a pointer
    SYMBOL PORT_PIN = PORTA
    while PORT_PIN.0[pin] = 0
    Worth a try I guess, unable to test.
    or a loop of
    mybyte = portA
    while mybyte.0(pin) = 0
    By the way re: "You are right, bit shuffling and time wasting"
    MOVE?BB PORTA, _B0
    AND?BCB _B1, 00Fh, _B1
    NCD?BB _B1, _B0
    LABEL?L L00002
    thats the size of the code in assembly using ncd added the "and" to remove msb
    xnihilo's Avatar
    xnihilo Guest
    Quote Originally Posted by sinoteq View Post
    Hi
    Yes, I am using interrupts on PORTA.
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 14:55
  2. DS1820 with 16f688
    Last Post: - 23rd May 2009, 06:07
    Last Post: - 13th December 2008, 18:11
  5. Another RTC, DS1287
    Last Post: - 12th December 2006, 18:07
