I know I already opened a post for this but after reading it again some month later, I could still not find the answer.
In the first step I need to know what pin triggered an interrupt, so I'm using:
In the second step I have to read the pin that changed, logicaly it would be:Code:if (porta.0 == 0) THEN pin = 0 'set the number of the pin for the score managment (update_scores) GOTO got_pin 'bypass ENDIF if (porta.1 == 0) THEN pin = 1 GOTO got_pin 'bypass ENDIF if (porta.2 == 0) THEN pin = 2 GOTO got_pin 'bypass ENDIF if (porta.3 == 0) THEN pin = 3 GOTO got_pin 'bypass ENDIF if (porta.4 == 0) THEN pin = 4 GOTO got_pin 'bypass ENDIF 'don't check A.5 which is an output got_pin:
But id does not work.Code:WHILE (PORTA.0(pin) = 0) ...
I don't want to use the same code for all 5 porta pins I'm using.
Isn't there a way to access pins using an index variable?
