Current flow controller for DC Motors
Results 1 to 25 of 25
    Feb 2005
    Kolkata-India
    Default Cannot use Logic Gates
    The SG3525 has an internal 5 volts reference but that is only for the comparator, ramp generator. It has got an internal under voltage lockout function whenever the supply drops below 8 volts (i hope i recalled correct)
    The output drivers are designed to directly drive MOSFET gates so if you use a 12 volts regulator to supply the chip. You are good to go. The fast turn-off issue becomes more important when you are switching at a much higher speed. So go ahead with the circuit.
    Sougata
    Italy
    Quote Originally Posted by sougata View Post
    So, could be ok to power the chip with 12V and the motor with 24V through the MosFET?
    Please note that I have to run the motor with 24V dc.
    Thanks.
    Feb 2005
    Kolkata-India
    Default Yes
    Try out the circuit and then if you need some intelligence / monitoring hook up a PIC micro to the same. In fact with an ECCP module on any of the PICs things are easy in software too.
    Sougata
    Italy
    Ok, I'll try it as soon I can get one SG3525 part.
    Italy
    Smile It work
    Hi guys,
    this is just to thank you all.
    I've got the SG3525 part. My motor was running using Logic-level rated mosfet. The IRF740 did not produced any result. Motor not running but it make noise like a whistle. Pretty normal, but no turning of the shaft.
    Once substituted with a P30N06 logic level mosfet, then voila. Motor running and SG3525 able to regulate the speed up and down.
    Thanks again.
  1. High current motor speed controller
    By George in forum Off Topic
    Last Post: - 2nd February 2007, 03:37
  2. 16F628A current high during sleep
    Last Post: - 9th October 2006, 10:21
