Current flow controller for DC Motors
Results 1 to 25 of 25
    What about an automobile/truck circuit breaker. They reset on their own and normally will handle a bit more amps than rated for a short time.
    But if the shaft is locked then you do not want it to keep trying? So a latching relay tied in with the circuit breaker might do the trick.
    Italy
    Uhmmm..
    It could work.
    I was looking for some more sophisticated solution (like transistors that regulate the current flow right to the thereshold)...
    Quote Originally Posted by mikebar View Post
    Uhmmm..
    It could work.
    It's called 'foldback' in a regulator circuit.
    http://en.wikipedia.org/wiki/Foldbac..._supply_design)
    Totally useless link, but it might get you started...
    EDIT:
    http://www.national.com/appinfo/power/files/f4.pdf
    Better link...
  1. High current motor speed controller
    By George in forum Off Topic
    Last Post: - 2nd February 2007, 03:37
  2. 16F628A current high during sleep
    Last Post: - 9th October 2006, 10:21
